What are the Fourier transforms for the step and ramp functions?
As well stated by Prof. C.P. Quevedo: "The idea of saying that such functions are periodic, with infinite period, no longer applies (the function never returns to zero and do not have the opportunity to repeat, neither in the infinity". This is where enters the Laplace Transform. By introducing a real term \$\sigma\$ in \$s = \sigma + j\omega\$, it is possible to make the "Fourier Transform" integral (now a Laplace Transform) to converge.
$$F(s) = \int_{^{^0{-}}}^{\infty}f(t)e^{^{-st}}dt $$
In fact, the main goal of the Laplace transform is to convert a differential equation into an algebraic equation (like logarithms). After, to operate in the complex domain, expand the result with partial fractions return to time domain using (normally) transformer tables; not only to a sinusoidal signal inputs. Also, It should be remembered that the frequency response (sinusoidal) is just one of the transfer function applications.
Fourier series: A periodic time signal is seen as an infinite sum of sinusoids (discrete frequencies, harmonics).
Fourier transform: A not necessarily "periodic" time signal is seen as an infinite sum of infinitesimal scaled sinusoids (continuous frequencies). Sum -> Integral.
Laplace Transform: A not necessarily "periodic" time signal is seen as an infinite sum of infinitesimal exponentially scaled sinusoids (continuous frequencies).
ADDITION:
\$\sigma\$ comes into play when when the concept of frequency is generalized to "complex frequency". When you write
\$Ae^{kt}\$, the exponent should be dimensionless; so that \$k\$ should be \${second}^{-1}\$. Note the similarity with "Hertz", ie it is a type of frequency. For example, in \$Ae^{2t}\$, the \$2\$ is the frequency (events per second) with which \$A\$ will be multiplied by \$e\$.
The unit of this "frequency" is Neper/second. Thus $$s [complex Neper/ second] = \sigma [Neper/second] + j\omega [radians/second]$$
Now an exponential function has a frequency, even though it differs from the traditional concept. In the Laplace Transform, the \$\sigma\$ is an appropriate value (but not only) for the integral to converge.
