I am currently panicking slightly because I need PSpice to work properly so I can simulate some diode circuits for my upcoming lab. However, what is happening is that when I try to run the circuit below, PSpice will simulate it once correctly (and show the output graph) with the simulation settings, and then if I change the simulation settings and try to re-run it, PSpice won't open the simulation. Sometimes the simulation fails with an argument error and a can't find error right after. Any help would be greatly appreciated!
This is what I'm trying to simulate: enter image description here
Where Vin is VSIN with 3V amplitude and 1000Hz, no offset. The diode we are using is the D914 (starts with a D, has the number 914 in it). The capacitor is 22uF, and R_L is 5k ohms. When I run simulate this without the capacitor PSpice seems to work correctly, but if I add the capacitor, it seems to only simulate once, and then not work correctly after that, or the simulation will just crash.
This is what I have in PSpice itself for this circuit with the above values: enter image description here
    \$\begingroup\$ Why don't you have one of the nodes marked as ground? All spice programs I've used need exactly one of them. (A node called "0".) Otherwise the entire circuit is floating. \$\endgroup\$
    – jonk
    Sep 14, 2016 at 23:52
    \$\begingroup\$ @jonk That diagram is actually just a diagram of what we're supposed to be making generally in PSpice, I've updated my post to reflect my actual circuit in PSpice that won't simulate correctly. \$\endgroup\$
    – Yuerno
    Sep 15, 2016 at 0:03
  • \$\begingroup\$ Ah. Okay. So.... that's weird then. Hmm. I've another thought. Will add it to my answer. \$\endgroup\$
    – jonk
    Sep 15, 2016 at 0:04
    \$\begingroup\$ Try added a big valued resistor (100M or so) to your diode's anode to ground. \$\endgroup\$
    – jonk
    Sep 15, 2016 at 0:10
  • \$\begingroup\$ Not exactly an answer to your original question, but have you tried the same thing with LTspice? Same result? \$\endgroup\$
    – winny
    Sep 15, 2016 at 9:15
Try adding a ground node (see left side):
The netlist would be something like:
R1 N2 0 5k
C1 N2 0 22µ
D1 N1 N2 1N914
V1 N1 0 SINE(0 3 1000)
Just note the use of 0 for ground.
EDIT: Okay. So you are using a ground. That's good. There is often a parameter to let you arbitrarily connect every node to ground via a high impedance value (GMIN.) But I don't know how you'd access it in your simulator. So lacking that, try the schematic on the right side, now, as shown above.
    \$\begingroup\$ So after doing some fiddling around, it seems to be just a weird issue with PSpice. If I simulate the circuit, change my parameters, hit simulate immediately, it doesn't seem to work. If I give it a couple of minutes, then PSpice will do the simulation. Just to test if it was something wrong on the circuit's end, I tried simulating the same circuit using LTspice, where it worked immediately. \$\endgroup\$
    – Yuerno
    Sep 15, 2016 at 3:38
  • \$\begingroup\$ @Yuerno Okay. Looks like you have some problem with PSpice. You might look at the settings to see if you can find something. I'm glad you have LTspice as a backup plan. You may need it if you continue to have problems with your PSpice installation. Best wishes. \$\endgroup\$
    – jonk
    Sep 15, 2016 at 5:00
