I want to send HTTP parameters using POST method through SIM908 GPRS. Here is and example of what I want to send:
POST /path/... HTTP/1.1
User-Agent: SIMCOM_MODULE
Host: website_name
Content-Type: application/josn; charset=utf-8
Content-Length: Length_num
Accept-Language: en-us
Connection: Keep-Alive
Requst_Body
I have visited this answer: Posting to php server using SIM900 GPRS with AT commands for using POST method to send data but this includes just the request body. What about the request parameters (headers)?
Is there any method to send them through HTTP or should I send them using TCP packet and how can I do it?
  • \$\begingroup\$ This is not an electrical engineering question. Sorry, but you have posted on the wrong site. Also you are missing links to datasheets for the device. \$\endgroup\$
    – Transistor
    Sep 18, 2016 at 8:38
For custom client headers use the AT+HTTPPARA command with HTTPParamTag set to USERDATA. It is described in Simcom AT Commands Manual.
  • \$\begingroup\$ This is not working, at least for the SIM900R chip. If you have examples will be great to look at \$\endgroup\$
    – Maxxie
    Feb 15, 2017 at 14:28
SIM908 does actually support post even though it is poorly documented:
AT+HTTPINIT
AT+HTTPPARA="CID",1
AT+HTTPPARA="URL","http://108.167.133.20/.../index.php"
NB*** AT+HTTPDATA=, ****NB
Wait for DOWNLOAD response then send data (bytes needs to be exact)
AT+HTTPACTION=1
AT+HTTPREAD=1,100000
