Pcb image
This is a motor controller for evaporative air cooler. I'm new to electronics so I'm trying to understand this chip upside down. But I have a problem with these components. 1. Q2 , I think it's transistor but I'm not sure. 2. EC3 (ss 100 16v) i think it's an oscillator but who knows. 3. EC4 battery? 4. REC1 no idea what it could be. 5. The IC f8234. I looked for the datasheet online but couldn't find anything. and I would like to know if it's possible to draw the schematic from the pcb for more understanding of the controller.
  • \$\begingroup\$ Q2 : transistor. (You can look up its markings) EC3 and 4 : electrolytic capacitors. REC1 : remote control (infra-red) receiver. f8234? good luck with that. It's probably a mask programmed MCU with no available data. \$\endgroup\$ Sep 18 '16 at 14:15
  • \$\begingroup\$ Thanks a lot! what is a "masked" programmed MCU? \$\endgroup\$
    – Amjad Izz
    Sep 19 '16 at 23:03
  • \$\begingroup\$ It's one that you don't get to read or reprogram, as it was programmed by a "mask" layer when the chip was made. \$\endgroup\$ Sep 19 '16 at 23:54
Q2 is a SMT transistor in what's known as a SOT-23 package -- there will be a short (3 character or so) code marked on it that can be looked up in a SMT guidebook online to find the full part number. ECx are electrolytic capacitors (why EC and not C? designer preference I suppose). REC1 is a remote control IR receiver -- these are basically commodity parts these days. The IC is indeed probably a microcontroller, perhaps mask programmed and house or otherwise custom marked instead of carrying full manufacturer markings.
  • \$\begingroup\$ Much Thanks ! so the REC1 could be used for remot control? Also, how can I get myself a schematic to know how exactly the circuit works? \$\endgroup\$
    – Amjad Izz
    Sep 19 '16 at 23:05
  • \$\begingroup\$ @AmjadIzz -- you won't be able to figure out much from one as the IC does all the grunt work. \$\endgroup\$ Sep 19 '16 at 23:12
