Could someone explain how PWM capture mode employs the Timer's Master-Slave mechanism? The example sets up input capture on Channel 2 but does not explain how IC1 is configured implicitly to capture the falling edge.
I am especially interested in these three SPL functions:
 /* Select the TIM3 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);
  /* Enable the Master/Slave Mode */
  TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);
implemented in stm32f10x_tim.c. They all write to TIMx->SMCR.
According the diagram from UM0008 rev 14 (rev 16) ...
ST UM0008 rev. 14 Figure 100. General-purpose timer block diagram
... TI2FP2 is not even connected to IC1, that would be TI2FP1. So I can understand that these commands configure the reset. But what causes IC1 to capture?
  • \$\begingroup\$ Note that in UM0008 section "15.3.6 PWM input mode" suggests that both capture units be configured, which the example does not do. \$\endgroup\$ – handle Sep 19 '16 at 9:46
It just caught my eye that the PWM_Input example uses TIM_PWMIConfig() instead of TIM_ICInit() as the InputCapture example does. This is where the missing part is happening: it also configures the other input capture channel. Note that the automatic reset apparently only works for channels 1&2, not 3&4, as their signal is not connected to the "Slave mode controller".
