This question already has an answer here:
I am working on a design where I need to amplify a small ac signal (a few μv, 1 Mhz) with a gain of 30 to 40, while introducing as little noise as possible. The input is driven by another op amp, so a high input impedance is not a requirement.
Currently I am using an op amp configured as non inverting amplifier. Even if the high input impedance is not required, the physical separation between input and output kind of makes me feel comfortable.
However when searching online I see a lot of examples where inverting amplifier configurations are used in similar situations, which made me wonder whether it might be advantageous to switch to an inverting design.
After some research I still could not find any particular reason why I might use an inverting amplifier in this scenario. Neither do I need an amplification of less than 1, nor a summing amplifier, as mentioned in answers to similar questions (1, 2).
So is there any particular reason why I would use an inverting amplifier if I am just amplifying a voltage with a gain of more than 1 (maybe considering noise, stability or other issues)?
EDIT: Just to clarify, I am talking about following op amp configurations:
Non inverting amplifier (left) and inverting amplifier (right):
marked as duplicate by Leon Heller, brhans, pipe, Armandas, Daniel Grillo Sep 20 '16 at 12:13
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    \$\begingroup\$ Usually an inverting amplifier configuration means that the inputs of the opamp stay at a constant voltage (virtual ground) as opposed to the non-inverting configuration where these will be a signal present on the inputs, often the input signal itself. If a high input impedance is needed, the non-inverting amplifier is the way to go as the inverting amplifier has a resistor to virtual ground as input. Now decide yourself what you need. \$\endgroup\$ – Bimpelrekkie Sep 19 '16 at 14:50
    \$\begingroup\$ Realize that parasitics start to take over when you move to higher and higher frequencies, pins and traces have pF's of capacitance between them and nH's of inductance in the pins and wires. These effects are usually noticeable at 30Mhz+ \$\endgroup\$ – Voltage Spike Sep 19 '16 at 16:04
    \$\begingroup\$ The graphs in the DS tend to shopw that an inverting gain has better bandwidth at higher gains and this means a better quality output signal usually. \$\endgroup\$ – Andy aka Sep 19 '16 at 17:38
    \$\begingroup\$ Inverting is usually the choice where low distortion is important. Noise should not be different for the same gain. \$\endgroup\$ – Spehro Pefhany Sep 19 '16 at 17:39
    \$\begingroup\$ It's because the common mode voltage does not change in an inverting amplifier. \$\endgroup\$ – Spehro Pefhany Sep 19 '16 at 18:03
Inverting amplifiers have less input impedance. This is because of the feedback resistors. A non-inverting amplifier has very high input impedance, because the signal is applied directly to the positive terminal.
For a low noise amplifier you want the input impedance to be low. This is because the noise current can generate large voltage drops otherwise. See this TI app note for the op-amp noise model.
Of course you can always put a resistor to ground on the positive terminal in order to decrease the input impedance and/or match for bias current.
For a low noise amplification I would use a transistor amplifier anyway. You can get transistors with tiny noise figures. The only reason not to use them is if you need a DC coupled amplifier. You also benefit from Friis' noise equation.
