I am designing a PCB that will incorporate a HiLink HLK-PM01 AC-DC converter.
The only AC that will be on my PCB is the two connections between the AC pins on the HLK-PM01 and a screw terminal header that I can connect the mains cable to.
I have these two traces in one corner of the board, and there is no copper within 8mm of these traces. I believe that keeping the traces away from ground pours and any signal traces is good, however as I would also like to know if there is an effective way to connect Earth directly to the PCB?
I was considering a small copper ring around the AC traces, that is earthed, so if for whatever reason a live voltage did jump across the board, the first thing it would find would be an earthed section of copper.
While I thought this sounded sensible, I can't find anything online that shows such a technique, and that makes me think it probably isn't a good idea.
So can someone tell me if there is an effective way to earth a mains section of a PCB to increase safety and reduce potential noise?
  • \$\begingroup\$ Please draw a block diagram or picture of your setup. Is this for a product? Because if it is there are standards that apply. \$\endgroup\$
    – Voltage Spike
    Sep 21, 2016 at 16:08
    \$\begingroup\$ Picture Plese see the layout here, everything under the black scribbling is 3.3V DC, The yellow box is where the HLK is, and the blue traces in the bottom right are my AC. I was thinking about surrounding them with an earthed ring? \$\endgroup\$
    – Steve
    Sep 21, 2016 at 16:17
    \$\begingroup\$ I edited your post to include your image. I also removed a signature. Signatures are just not part of how SE works. To thank other users, upvote their answers when they are helpful to you. \$\endgroup\$
    – The Photon
    Sep 21, 2016 at 16:21
    \$\begingroup\$ With your blue traces like that, there is less than 3.5 mm of creepage distance between them (HLK-PM01 input terminals are spaced 5 mm, the traces are at about 45°). You could route them left-and-up and up-and-left and mill a slot between the AC input terminals and between the PSU input terminals to increase the creepage significantly. For safety. N.B. I am not an electrical engineer. \$\endgroup\$ Sep 21, 2016 at 19:19
  • \$\begingroup\$ Just a note that the "redaction" you did is almost totally reversible. \$\endgroup\$ Jan 14, 2019 at 7:51
N.B. I am not a qualified electrical engineer. The following is from what I have learned.
If you are concerned about voltage spikes causing mains voltages to appear on the PCB where they shouldn't then your fused mains input should have a surge suppressor on it before it gets to the PCB.
With your blue traces like that, there is less than 3.5 mm of creepage distance between them (HLK-PM01 input terminals are spaced 5 mm, the traces are at about 45°). You could route them left-and-up and up-and-left and mill a slot between the AC input terminals and also between the PSU input terminals to increase the creepage significantly:
PCB alteration
(The purple lines are for the traces, the green lines for the slots. You will have to consult the relevant standards to determine the width of the slots. Your PCB fabricator may be able to advise you.)
You could use a metal case and connect it to the mains ground - use a crimped connector and shake-proof washers (a machine screw instead of a bolt is likely to be better for you):
Proper ground connection
(Image from http://www.streetrodlife.com/tech/getting-grounded/)
If you use a metal case then you may want to add extra electrical insulation between the underside of the PCB and the case.
You do not want a spark gap for the mains traces on the PCB, in case you were thinking of that. Leave that function to the purpose-made surge suppressor.
You will then have done everything reasonable to protect against failures w.r.t. mains voltages getting where they should not.
Further reading: Grounding for the control of EMI.
There are clearance and creepage requirements, depending on what certifications you need. See here for starters. Don't put a copper ring around the AC traces for three reasons.
1) Mutual inductance Depending on the traces and how they are connected to ground you could make some nice antennas,
2) Small traces If your making a guard ring for AC traces, they would have to have more current capacity than your AC traces to sink current to ground and if you do have AC jumping from point to point on your PCB, its going to vaporize any copper it touches until it the air gap gets too wide. AC to your PCB is like an infinite source of current, it can do bad and destructive things.
3) Creepage and clearance This is up to the regulatory standard of your choice (IPC, IEC or other) but in general you shouldn't have anything within 40mil MINIMUM of your AC traces. It really depends on what they are, if your designing for 220V or 120V and other factors like PCB material, pollution degree and other factors. You will also want a large distance between any DC path and AC trace.
These are just some of the very very basics, start opening up power supplies (unpowered of course) and look at the layouts there.
The idea behind grounding in a system is that the fault current goes out through the enclosure, and blows the fuse (fuses are required). You don't want AC to terminate in your PCB especially in your DC subsystem. PCB's are high impedance >10^8 Ohm. enter image description here
  • \$\begingroup\$ Thanks for the info, the core of my questions is how should I effectively add Earth to increase safety if a guard ring is not the way to do it? \$\endgroup\$
    – Steve
    Sep 21, 2016 at 16:32
