I have to replace a capacitor from a motherboard, but I can't find any information about the manufacturer, capacitance, voltage, tolerance and ESR values.
I suppose the capacitance is: 330uF (not sure, because I've found online that the coloured band can indicate the multiplier 10^-1, 10^0, 10^1,...) and voltage: 2.5v, but nothing about manufacturer, tolerance and ESR.
Here the image (3H5 VLPU 330 2.5v) enter image description here
Can you help me please?
Thanks,
Alessandro.
  • Possible substitute in stock
    • 1st is 16 mOhm ESR vs original 12mOhm
    • 2nd is 10 mOhm ESR Aluminum Polymer low profile low ESR 330uF 2.5V
http://www.digikey.com/product-detail/en/nichicon/RSL0E331MCN1GB/493-3817-1-ND/2239372
http://www.digikey.com/product-detail/en/panasonic-electronic-components/2R5SVPE330MY/P16533CT-ND/4204340
I would go with 2)
in future Lookup 330uF 2.5V and check photos and compare specs. and [X] in stock and cut tape for SMD (1pc)
| improve this answer | |
It is a polymer cap by Matsuki Polimer. Datasheet can be found here.
As you guessed: 330uF, 2.5V.
VLPU is the name of the product series.
3H5 is the datecode (couldn't find how to translate it).
  • \$\begingroup\$ The date code could be, maybe, the 4th week of august for one year that end with 3 (1993? 2003? 2013? I don't know...). I found this info here but i don't have any other info about standard, meaning, etc (surely in IEC 60062 there's noting about this 3-character date code). \$\endgroup\$ – Antonio Sep 22 '16 at 12:24
