ModelSim is unable to compile this in VHDL:
constant mem_size_bytes: integer := x"FFFFFFFF";
It says:
Bit string literal found where non-array type std.STANDARD.INTEGER was expected.
Similarly for;
if address< x"3FFFFF" then
it says
Operator "<" is ambiguous
I keep running into this problem. How in the world am I supposed to use hexadecimal numbers in VHDL with integer types like integer, natural and positive? Its just that specifying something hexadecimal is more convinient at times than having to use the calculator to determine what something is in radix-10. I had hoped that the tool will automatically know what the literal means since it is preceded by x which marks it as hexadecimal numeric quantity!!!
So, when assigning literals to constants or when using literals in comparison operator how does one qualify the literal? In other word for a literal constant value like "1010", how do explicitly tell the compiler if this is a string or std_logic_vector or unsigned or signed?
    \$\begingroup\$ See based_literal, where the the negative one expression (for the minimum supported integer size) would be 16#FFFFFFFF#. Integers are scalar while bit strings and string literals are associated with arrays of character types (and std_ulogic is a character enumerated type). Simply put, integers don't got bits. \$\endgroup\$
    – user8352
    Sep 23, 2016 at 5:26
VHDL supports arithmetic values but it has to know if they are signed or unsigned. I recommend using the numeric_std library to support these types.
VHDL is strongly typed. For your first question, I would use:
EDIT: I have erased a prior more complex form and used this simpler one after Brian Dummond's comment
constant mem_size   : integer := x"FFFF_FFFF";
The second, supposing address is an std_logic_vector, has to be written:
if unsigned(address) < x"3FFFFF" then
    \$\begingroup\$ Downvoted for recommending unnecessary type conversions. Prefer the simpler solution of using the right syntax 16#3fffff# for based integer literals. \$\endgroup\$
    – user16324
    Sep 23, 2016 at 10:29
  • \$\begingroup\$ I did not know about this # format. None of the resources I have show these. I will try it out. \$\endgroup\$
    – quantum231
    Sep 23, 2016 at 13:51
  • \$\begingroup\$ Ok, how does one qualify the literals that are string of bits like "1010" as std logic vector, unsigned, signed or something else? \$\endgroup\$
    – quantum231
    Sep 23, 2016 at 13:54
    \$\begingroup\$ For vectors of bits or of std_logic, either "1010" or x"A" work. For base 2 integer literals, 2#1010#. And of course, 6 * 9 = 13#42#. \$\endgroup\$
    – user16324
    Sep 25, 2016 at 10:28
    \$\begingroup\$ @quantum231 then none of your resources are a decent textbook. I still turn to Ashenden "Designer's Guide to VHDL" most often. \$\endgroup\$
    – user16324
    Sep 25, 2016 at 10:32
