NOTE: I have been using this as a reference.
After recently purchasing a SIM5320A breakout board (the board) I have been trying to connect it to a TCP server. After having to connect the board to an Arduino and turn the Arduino into a middle man (Data Mode, wouldn't receive +++ over the USB connection). I have tried using Data Mode (I can receive data, but I can't send anything) and Command Mode (whenever I try to use AT+CIPOPEN=0,"TCP",[IP address in quotes],[port] I get +IP ERROR: Operation not supported).
All I need to be able to do with this is open a stable TCP connection with the server and receive and send data. If sending data from Data Mode is easy enough, I would like hear that solution first, but solutions to get the connection in Command Mode are equally appreciated.
  • \$\begingroup\$ Have you set up the PDP context? Obtained an IP address from the service provider? Post your sequence of commands so far. \$\endgroup\$ Sep 24, 2016 at 2:00
  • \$\begingroup\$ I have experience only with SIM800f, but for that you can find some tutorials from the internet. For exampe this \$\endgroup\$
    – olltsu
    Sep 24, 2016 at 5:43
Turns out that the issue that I was having is that I was not using the commands AT+CGSOCKCONT=1,"IP","CMNET" and AT+CSOCKSETPN=1 before opening the TCP socket.
If you are trying to get the SIM5320 to open a transparent TCP connection, the commands you need to send are: AT+CGSOCKCONT=1,"IP","CMNET" AT+CSOCKSETPN=1 AT+CIPMODE=1 AT+NETOPEN AT+CIPOPEN=0,"TCP","TargetIpOrDomain",TargetPort
When you are ready to end the session, you send +++ to the chip to enter command mode. To close the connection you use AT+CIPCLOSE=0 and AT+NETCLOSE to turn off the network connection mode.
