This question already has an answer here:
I was just learning about the port configurations of the GPIO pins. I came across the open drain configuration, and I was bit confused. I could not understand this properly. When this should be enabled or disabled? Should this be always enabled when the port is configured for output while transmitting?
marked as duplicate by pipe, Daniel, gbulmer, DoxyLover, Armandas Sep 24 '16 at 7:30
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ It sounds to me that you have a particular use case in mind, that you failed to specify. What do you mean by "transmitting"? \$\endgroup\$ – pipe Sep 24 '16 at 4:54
The simplified view of a digital "output" is simply two transistors, one connected to the ground, one connected to the circuit input-output power supply (Vio).
When and output is configured in "push-pull" mode, outputting a '0' connects the output pin to the ground, a '1' connects it to Vio. In "open drain" mode, the "higher" transistor is always disabled: '0' still connects the output pin to the ground, but outputting a '1' does not connect the pin to Vio, and it's left "floating".
Configuring a pin as push-pull or open drain is a choice you make during a circuit design, depending on what you want to achieve.
