I have a number of 7 pole single throw switches that I need to connect together in some sort of grid configuration to a microcontroller, while minimizing the number of pins on the micro and the number of diodes/other elements I need.
The controller needs to be able to uniquely distinguish each switch regardless of how many of them are open or closed at a given time; presently there are 17 different switches.
I also do want to have some degree of redundancy on the mechanism - it is possible that one or two of the switch's poles might fail to make contact and remain open. (The other failure, accidental closure, is not an issue.) Ideally I would like to allow for up to two failures per switch without compromising the ability to register each input.
I have considered a few conventional methods: With a conventional switch matrix, \$n\$ pins gets you \$(\frac{n}{2})^2\$ switches and needs \$(\frac{n}{2})^2\$ diodes. Charlieplexing the switches would increase this to \$n^2 - n\$ switches while reducing the number of diodes to just \$n\$.
Both these have the advantage that I can just combine all the poles together and get my redundancy there. However, I would guess there might be a clever way to connect them taking advantage of the multiple poles to reduce or possibly eliminate the need for extra diodes.
How can I take advantage of the multiple poles to reduce the number of needed diodes while still maintaining some level of redundancy in the switch network?
