I read about li-ion battery charging and it requires monitoring for the voltage and current, How does those extremely cheap phone chargers do that? Or Is it just an adapter and the charging circuitry are embeded into the phone?
    \$\begingroup\$ Li-ion charging is the easy part though, chips that do it properly cost around $0.40 (see e.g. MCP73811). The hard part is safely converting 230V/110V mains to +5V. \$\endgroup\$ – jpa Oct 2 '16 at 15:50
12
The device (phone, etc.) has the special charging circuit built-in. And the battery pack typically has a special circuit inside to prevent excessive discharge (or charging). Li-ion battery cells are inherently unstable/dangerous and require special circuits somewhere (often built into the battery pack) to make them safe to use.
  • \$\begingroup\$ Though exactly because they are so dangerous, the protection circuits are usually very good, rendering the pack itself quite safer than other batteries \$\endgroup\$ – Kroltan Oct 2 '16 at 12:12
  • \$\begingroup\$ MOSTLY "very good" but we keep hearing of spectacular failures. Perhaps only my perception but the rate of failures and incidents seems to be increasing with time. \$\endgroup\$ – Richard Crowley Oct 2 '16 at 16:09
    \$\begingroup\$ @RichardCrowley Number of devices produced per year with a Li-ion battery is going up fast. Plus, it's more and more common to use them e.g. on aircraft, where if something goes wrong it'll hit the news. \$\endgroup\$ – Someone Somewhere Oct 3 '16 at 4:20
    \$\begingroup\$ @RichardCrowley If you ever work with unregulated Li-Ion batteries, you will learn exactly just how dangerous they are. DIY RC devices fall in this category and things will just randomly blow up. The commercialized Li-Ion products have very significant safety margins. \$\endgroup\$ – Nelson Oct 3 '16 at 8:07
    \$\begingroup\$ Because a fire on a plane or boat is easily mass life endangering and yet the device can easily be hidden / missed without this labeling. Poisonous snakes come with far less warnings for travel as people expect them to be dangerous. \$\endgroup\$ – djsmiley2k Oct 3 '16 at 11:23
6
The charger doesn't charge the battery. The actual charging circuit is in the phone; the so-called "charger" just provides a constant-voltage power supply to the charging circuit (and the rest of the device).
The key to how it is possible to have cheap phone chargers made, is a combination of economies of scale, and cutting corners. Cheap chargers (and some expensive chargers) will generally work but the compromises made to reduce costs are generally at the cost of safety, particularity in poor isolation between mains power & the regulated output (ever had a bit of a tingle while touching charging devices?). They will generally also offer a shorter lifespan due to running components much closer to their maximums.
However these cheap phone chargers, simplify provide a constant voltage supply (at 5V to the device being charged) it is then the devices responsibility to regulate the current and control the cut off point. In general phones are a more expensive and better engineered device but faults do still occur.
Chips that handle common, simple logic cost pretty much the cost of the materials. There are few things more common than charging logic, so any logic circuits you use cost mere cents.
Of course phones charge through USB, which in this case is nothing little more than a glorified 5 Volt DC wall socket. That means any charging logic has to be on the device side. But even standalone battery chargers are dirt cheap to manufacture. (I'm not endorsing that specific product, all I know is it's a standalone battery charger and it's dirt cheap).
So everything is true:
  • Charging logic is in the phone.
  • Protection logic is in the battery.
  • Battery chargers are dirt cheap to manufacture.
protected by W5VO Oct 2 '16 at 22:20
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
