I am currently using a MCP73831 to charge my Li-Ion battery. Once the battery is charged I can use a switch to turn on my circuit.
Power Supply
So right now : USB-B -> MCP -> Li-Ion -/-> Circuit.
It means that when my battery is charging, the rest of the circuit is turned off. What I'd like to do is to do both at the same time: charge the battery and power the circuit. So that when the USB cable is not connected, the circuit drains the battery. And when the USB cable is connected, the circuit is powered directly from the USB while the battery is charging.
Ideally I don't want to use any manual switch, so that everything is automatic.
I thought of two options that obviously don't work:
  • Removing the switch on the schematic above. But the battery would not be charged properly. (And I'm not even sure the circuit would work because of the battery charger behavior).
  • Using a parallel branch from the USB but it would short-circuit the battery charger. (Unless I keep the switch...)
Some technical details:
  • The supply voltage can be anywhere between 3.7v and 6V.
  • The switch between Battery supply and (USB supply + battery charging) should be automatic (Unlike on this schematic).
Place a diode from Vdd (or Vin - same junction though) to the cathode of D1.
This will work just like an OR gate: Your circuit will be powered from Vin if (Vin - 0.6V) > Vbattery. Otherwise, the circuit will be powered from battery. You can use a germanium diode in order to reduce voltage drop on that extra diode.
|improve this answer|||||
    \$\begingroup\$ Use a Schottky for the diode if you want to reduce the drop as germanium diodes are worthless nowadays. \$\endgroup\$ – ThreePhaseEel Oct 2 '16 at 20:34
