I am trying to subtract one 8 bit number from another but I keep getting an error that "<=" is unexpected. The rest of it I am just AND-ing the 8th bit of each output. Can someone tell me what is wrong with my code?
module test(n1,n2,n3,z);
input [7:0] n1,n2,n3;
output [7:0] z;
wire [7:0] x1, x2;
x1 <= n1 - n2;
x2 <= n3 - n2;
and and1(z, x1[7],x2[7]);
endmodule
The <= operator can only be used within a procedural block.
A procedural block is begin with the keyword always or initial.
Since you haven't used either of these keywords, you can't use the <= operator.
If you want x1 and x2 to change whenever the inputs change, you should use an assign statement, for example
assign x1 = n1 - n2;
You should use either an assign statement like so:
or you can assign with the wire definition like so:
wire [7:0] x1 = n1 - n2;
