In the above diagram the circuit is in Series Resonance. Now we are asked to find the coupling coefficient K between coils L1 and L2. For which i first calculated L(equivalent) as follows :
Leq = L1 + L2 + 2M ( Dots are in aiding position)
Leq = 12 + 3 + 2M (Assuming w = 1)
Leq = 15 + 2M (M denotes mutual inductance between two coils)
So the circuit becomes
Since The circuit is in resonace the XL should equal to Xc
  Xc = XL
-jw18 = jw(15+2M)
 -18  = 15 + 2M ( w = 1)
  -16.5 = M
Now, To find coupling coefficient K, we can use the follow formula
K = M / sqrt(L1*L2)
K = -16.5/ sqrt(12*3) = -2.75
Which is not possible, Since Range of k should be 0 < K < 1. Where am i wrong ? Please Help...
Hint - if the two inductors were perfectly coupled (k = 1) then you would get a total reactance of j27 ohms. Are you able to see that? If you are then clearly, to obtain a total reactance of j18 ohms k must be less than 1.
How did I get j27 ohms - it's a sanity check - reactance or inductance is proportional to turns squared and if coupling is 100% then the turns for L1 and L2 are perfectly coupled and can be regarded as being on the same former so, new impedance is \$j(\sqrt{12} + \sqrt{3})^2\$ = j27 ohms.
I think the mistake I see is that you equate the reactance to -j18 when in fact M should equal j3.
  • \$\begingroup\$ @MayankPal Did this answer help you? \$\endgroup\$ – Andy aka Oct 25 '16 at 16:57
Here equivalent Inductance is 15+2M but in resonance condition capacitive reactance equal to inductive reactance so here 18=15+2M then M value becomes 1.5 from this K=0.25
