How to reduce \$(\bar B.C + B)\$ to \$(B + C)\$?
Idempotent Law
A * A = A
A + A = A
Associative Law
(A * B) * C = A * (B * C)
(A + B) + C = A + (B + C)
Commutative Law
A * B = B * A
A + B = B + A
Distributive Law
A * (B + C) = A * B + A * C
A + (B * C) = (A + B) * (A + C)
Identity Law
A * 0 = 0 A * 1 = A
A + 1 = 1 A + 0 = A
Complement Law
A * ~A = 0
A + ~A = 1
Involution Law
~(~A) = A
DeMorgan's Law
~(A * B) = ~A + ~B
~(A + B) = ~A * ~B
  • 4
    \$\begingroup\$ I'm voting to close this question because you show no effort in solving this assignment other than copy-pasting all the Laws concerning Boolean logic. \$\endgroup\$ – Bimpelrekkie Oct 4 '16 at 8:32
  • \$\begingroup\$ I simplified Y = A'B'C' + A'B'C + A'BC'+AB'C+ABC'+ABC to A'(C' +B'C) + A(B'C+B), I'm literally at the last step but I just can't figure out why (B'C + B) can be reduced to (B + C) \$\endgroup\$ – JavaBeginner Oct 4 '16 at 8:35
  • \$\begingroup\$ You only apply the laws but you're not using your brain, just switch it on and see what happens. \$\endgroup\$ – Bimpelrekkie Oct 4 '16 at 8:37
  • \$\begingroup\$ I know the end result, I just need the proof \$\endgroup\$ – JavaBeginner Oct 4 '16 at 8:39
    \$\begingroup\$ Apply the distributive law, then the complement law and see what happens. The answer is literally staring you in the face. \$\endgroup\$ – crowie Oct 4 '16 at 8:58
Sometimes the best thing to do is to look at the truth table for the expression you are given.
\$(\bar BC + B)\$ gives this truth table.
Now, I am quite confident that you can see from this table why the \$\bar B\$ can be removed. Just think about it.
Alternatively, if you expand the original equation (otherwise know as applying Distributive Law), you get \$(\bar B+B).(C+B)\$, geddit yet?
| improve this answer | |
