I have designed a very simple PCB in EAGLE that should be approximately W: 10mm, L: 30mm in size. This design is repeated 18 times (I need many of them).
However, for some reason, the whole PCB is huge. I simply cannot find a feature to re-scale my whole design to the dimensions that I want. Is this available in the free-version? If so, how do I access and use it?
Any help will be much appreciated.
    \$\begingroup\$ What went wrong in the first place? Why is the PCB so huge? \$\endgroup\$
    Oct 4, 2016 at 10:07
  • \$\begingroup\$ I'm not sure. I though I had selected the correct units to work in (millimeters) but something seems to have happened to change that. It also appears to represent my cursor position in some sort of weird polar coordinate system rather than a Cartesian system. \$\endgroup\$
    – GBean
    Oct 4, 2016 at 10:10
  • \$\begingroup\$ I've never seen a feature like this in any package, free or not. Hey it's not a very big board so get cracking (LOL). You'll never make this mistake again! Hope you didn't have to create too many bespoke library footprints. \$\endgroup\$
    Oct 4, 2016 at 10:13
  • \$\begingroup\$ Just output the Gerbers for a single board. The PCB supplier can repeat it as many times as necessary. \$\endgroup\$ Oct 4, 2016 at 10:14
  • \$\begingroup\$ @Andyaka I'm worried that you're right about that. Just to be sure, where are the options for setting the units of the PCB on a fresh project? \$\endgroup\$
    – GBean
    Oct 4, 2016 at 10:21
It's hard to say exactly what the problem is from your vague description, but it seems you messed up something in the dimension layer. Start with only one copy of the board and verify it is correct. Then you can replicate that board after you know it's OK.
However, trying to panelize a board yourself is a bad idea in the first place. The board house is much better suited to do this, does this routinely, and has all the right tools for it. Send them a single copy of your board and tell them how many boards you want. They know the size of their panels, and for prototype services can rearrange your copies with that of others to fill up a panel.
Basically, this is a production detail that you as the electrical engineer shouldn't be in. Let the production people do the production in whatever way is most efficient for them. They tell you the price for different quantities of boards, and you tell them how many you want.
