13
If I replace an old, roof-mounted TV antenna with a 2.4GHz WiFi (IEEE 802.11) antenna; can I use the existing coax? Or will I need to run all new cable?
bubble.us
| improve this question | | | | |
  • 4
    \$\begingroup\$ You can also use an old copper bedpan as a wifi antenna, just that the reception will be shite... \$\endgroup\$ – PlasmaHH Oct 4 '16 at 14:55
    \$\begingroup\$ The usual solution for this issue is to use a weather-proof WiFi acesspoint/card(they usually come with N connector) screwed directly to the antenna and placed outside, on the roof. The card gets powered using Power over Ethernet and an Ethernet cable (specified for up to 100 m) runs to the router. This is also much cheaper, simpler and more maintainable than trying to install a proper coaxial cable to the antenna. There are also units that come with an integrated antenna as well. \$\endgroup\$ – AndrejaKo Oct 4 '16 at 21:25
    \$\begingroup\$ @AndrejaKo What about USB? I have a high-power 2.4GHz wireless network card, and a suitable weatherproof box & antenna. But the wireless card only has a USB port for power and data. No Ethernet port. \$\endgroup\$ – voices Oct 5 '16 at 0:21
    \$\begingroup\$ This seems more like a SuperUser question to me, but you might try something like the RouterBoard Groove, which has an N-connector for an antenna, comes with pole-mount gear, and uses passive PoE so you only need (outdoor-rated!) Cat-5 cable. They have similar products with a built-in directional antenna if that's what you want. I have no affiliation with RouterBoard other than as a happy customer. \$\endgroup\$ – Calrion Oct 5 '16 at 2:30
    \$\begingroup\$ Kinda related: SuperUser - WiFi signal loss on cable \$\endgroup\$ – PTwr Oct 5 '16 at 9:33
19
So you want to transport that 2.5 GHz (or even 5 GHz ?) Wifi signal over TV COAX cable ?
Indeed to the non-RF people you'd just think that would work. And it does BUT there will be almost no signal coming through that cable.
The Wifi signal will be attenuated so much in that COAX cable that it will defeat the whole purpose of having an antenna on the roof. The same antenna directly on the router might even get better coverage.
Why is that ?
TV COAX cables are not designed for 2.5 GHz signals, TV signals go up to 1 GHz and even at that frequency you can expect a lot of attenuation.
TV COAX cables usually have a characteristic impedance of 75 ohms, Wifi antennas routers etc. all use 50 ohms. There are no exceptions to that.
So no, in practice this will not work at all.
| improve this answer | | | | |
    \$\begingroup\$ Yes. ~2.4GHz; I believe. \$\endgroup\$ – voices Oct 4 '16 at 14:59
    \$\begingroup\$ WiFi cables that can support distances of more than a foot or two are purpose built devices. High quality RG213 cable can go up to about 30 feet and still be usable, but that's it. \$\endgroup\$ – David Schwartz Oct 4 '16 at 19:04
    \$\begingroup\$ So does a cables impedance determine the frequency/bandwidth for which it is useful? Is it directly proportional/relative/related? \$\endgroup\$ – voices Oct 4 '16 at 20:24
  • 4
    \$\begingroup\$ No, not directly. It is the whole design and build of the cable that will determine the attenuation at a certain frequency (so indirectly Bandwidth), the characteristic impedance and how much power the cable can handle. And its cost of course. A proper cable (low loss and including connectors) for up to 4 GHz can easily cost hundreds of Euros for just 1 meter of cable. At work we have cables for up to 80 GHz, they cost thousands of Euros for just one meter of cable. At high frequencies the signals tend to travel through air or space more efficiently !! \$\endgroup\$ – Bimpelrekkie Oct 4 '16 at 20:38
    \$\begingroup\$ Errrr it seems that 8 to 25 db PER HUNDRED METERS are common values for various brands of RG-213, not per foot. And UHF TV frequencies run up to 890MHZ - a cable suitable for that but giving 8db/ft at 1GHz would be quite a high order filter :) The Impedance matching issue, though, stands (not with RG-213 though, which is 50 Ohms - RG-179 would be a typical 75 Ohm cable). \$\endgroup\$ – rackandboneman Oct 5 '16 at 11:13
7
You must use coaxial cable of the proper impedance. The most common impedance for coax cable is 50 ohms or 75 ohms. If the cable you want to use matches the impedance of the interface AND the antenna, then go for it. But if you use cable of the wrong impedance you will get significant attenuation of the signal to the point where it may not work at all. In high-power equipment, it may even damage the transmitter. But that is unlikely in average WiFi gear.
What you can do instead is to bring the router to the antenna on the roof and use a pair of MoCA boxes to run Ethernet over your coax.
  • \$\begingroup\$ Ethernet →Coax? Interesting. Would that work with PoE as well? \$\endgroup\$ – voices Nov 3 '17 at 13:33
  • \$\begingroup\$ The MoCA box needs power, you can't run power and data both over coax AFAIK. Whether they have a built in PoE injector -- I doubt. But, since you need to have power around the MoCA box adding a simple PoE injector as well should be easy. Also, if you have power, powerline networking also comes to mind. \$\endgroup\$ – chx Nov 3 '17 at 13:47
  • \$\begingroup\$ Cool, I didn't mean at the same time. This question is about a year old now, so it's just out of general curiosity; I don't really know anything about MoCA. \$\endgroup\$ – voices Nov 3 '17 at 14:25
You definitely can use RG6 coaxial cable with WiFi frequencies, provided that you convert the impedance. The fact that RG6 cable is marketed as being "tested to 1 GHz," "tested to 3 GHz," etc. doesn't preclude its use with higher frequencies. Take a look at the 50Ω LMR coaxial cable running between the sector antennas and the base station at virtually any cell site - in the US, those cables support a mix of frequencies that include 1.9 GHz, 2.5 GHz, and with 5G, 5.8 GHz or higher. As for 75Ω RG6 cables, cablecos offering DOCSIS 3.1 plan to reach 1.794 GHz in the near future.
To run WiFi over RG6 cabling, the main issue is attenuation over distance and connector/assembly loss. RG6 can evidently support 2.4 GHz frequencies out to 210 feet, while LMR-900-DB can support 2.4 GHz out to 1,130 feet. All you need is two impedance converters per run, one between the WiFi radio/router and the cable run in your wiring closet, and another between the wall plate and WiFi antenna in another room. You can find kits that support this from coaxifi.com or dual-comm.com.
The other factor is the output power on the router's radio chain. More output power is better, especially if you plan to split the WiFi signal several times, so a 1 watt router would be ideal. But for passing a signal to just one other room over RG6, most routers with RP-SMA connectors should be fine, so long as the cable has no shorts and the distance isn't excessive (consult the coaxial cable calculator at timesmicrowave.com to see which distances have run efficiencies of 0.1% or higher).
If you do have an opportunity to run 50Ω cable natively in your home or office, go for it. It's a great way to connect outdoor panel antennas or ceiling antennas where you don't need to fumble with wall plates. I'd recommend LMR-600 cable if you can afford it (around $1 per foot wholesale) and have room for a 0.59 inch jacket diameter, but if not, LMR-240 performs better than RG6 at WiFi frequencies and also is slightly smaller in jacket diameter than RG6.
One answer to this question suggests that 1 GHz is some sort of cut-off frequency on RG6. Clearly, it isn't, otherwise DOCSIS 3.1 wouldn't work. "RF people" should know that the only coaxial cables with built-in stopbands are radiating-mode leaky feeder cables, and unless you're in a train tunnel, you aren't using that. Nor are the components involved exotic - F-SMA impedance converters wholesale for under 50 cents. People that install panel antennas for in-building WiFi DAS deal with this all day (there's even a pretty picture in L-Com's latest catalog showing a WiFi over coax deployment at a hospital).
  • \$\begingroup\$ Thanks. This is good info. I don't think I'm not familiar with DOCSIS, but I'll look into it. I've never heard of an impedance converter either. I mean.. How is impedence "converted"? What kind of circuit does that? \$\endgroup\$ – voices Nov 3 '17 at 14:06
  • \$\begingroup\$ Looks like the poster below covered it. A simple adapter with dielectric material can convert between 75Ω and 50Ω. N and BNC connectors come in both 75Ω and 50Ω versions, and adapters exist for other connector types. And DOCSIS is what underlies cable modem Internet. DOCSIS 3.1 can use up to 1.7 GHz, while MoCA 2.5 goes up to 1.5 GHz. Plus, low-noise block downconverters for satellite TV reception go up to 2.3 GHz. \$\endgroup\$ – Eric Johnson Nov 6 '17 at 23:28
Nearly all coax is quite lossy at those frequencies, for a run more than a few feet / a meter. If you can get it to work at all, performance will be quite poor.
A better solution is to get the transceiver as close to the antenna as possible, then do a long cable run from that.
A similar thing is done for satellite antennas - ever heard of an LNB? They amplify and downshift the signal right at the antenna, to mitigate the losses of a cable run.
The "LNB" is just an analogy - you need to put the access point outside, then run Ethernet cable from that. Power over Ethernet would be perfect for an application like this. Look up "outdoor wireless access point".
If you absolutely cannot run a new cable, here's a wild idea - use the existing coax cable just to provide DC voltage to the access point. Set up the access point to cross-band repeat, then use another access point inside to get the data onto the rest of your network.
  • \$\begingroup\$ So could I buy/build/customize something like an LNB to suit this purpose? \$\endgroup\$ – voices Oct 4 '16 at 20:08
Assuming 75 Ohm antenna design for cable TV coax, that causes a return loss
  • you can use semi-rigid coax with same SMA connectors used with proper DIY flange tool to make connector cable assemblies for lowest path loss in a reasonably long distance.
Also, cable TV signal loss gets pretty bad in the 1-5GHz range except satellite dish coax, but again, wrong impedance.
I would choose 50 Ohm semi-rigid coax and choose antenna that give gain in the intended direction. You may review flex coax loss per unit length and connector losses, so choose the best.
  • I use an application that measures RSSI from your WiFi chip and converts that to dBm and ensure that my signal is above -80dBm for 11Mbps and above -76dBm for 54MBps for marginally acceptable performance. Now that I got a new DLink router with 3 high performance antennae, I never have less than -45dBm in the house and can walk across the street more than 40m from the interior router and still have good Skype video calls where the signal gets close to marginal.
  • Line of sight gives the best distance.
When I was in New Zealand, 10 years ago, small beachside towns, some residents had networked all their routers to give wide area coverage to the beach using RIP protocol (an option in many old routers) with a designated router MAC address sharing. They used small Yagi antenna, pointed towards the beach area to ensure optimal gain.
Yes. Coaxifi (coaxifi.com) is an example of what you're describing. You could do it with an RP-SMA antenna, or use a kit with an F connector antenna. You would need to create a balun for impedance, but that is certainly doable. To your question about impedance conversion, this just means that the dielectric field strength is changed, with a slight signal loss for the conversion. Ham radio enthusiasts deal with this frequently, for instance, with BNC connectors as shown below. Comparison of 50 Ohm & 75 Ohm BNC connectors
Just to be clear, antennas don't speak protocols, so there is no such thing as an "802.11 antenna." (There are omnidirectional or directional antennas, ones that cover just 2.4 or 5 GHz and those that cover both bands, etc.)
  • \$\begingroup\$ No such thing as a WiFi antenna? I don't know about that.. But sure, point taken. I'm interested in the following statement: "You would need to create a balun for impedance, but that is certainly doable." That sounds like useful information. Can you elaborate on it a bit? \$\endgroup\$ – voices Nov 3 '17 at 14:19
  • \$\begingroup\$ What I mean is that 802.11n (for instance) covers both 2.4 and 5 GHz, so it'd be clearer to call the antenna "2.4 GHz," "dual band," etc. 5 GHz attenuates over shorter lengths than 2.4 GHz, but within a house, that shouldn't be a problem. And as far as baluns go, the setup would be to convert from 50 Ohms at the router's radio chain to 75 Ohms over RG-6, then back to 50 Ohms between the cable outlet and antenna. I see Coaxifi and Dualcomm have these sort of products. You can also find balun kits for Ethernet over coax (which are fairly common when supporting older CCTV camera systems). \$\endgroup\$ – wifivar Nov 4 '17 at 14:25
