I have transformer which is used for a sin-wave invert-er whose data are follows
**Primary Winding details : 250 Volt ,375 turns with 19 SWG copper .
Secondary Details : 7.5 Volt , 11 turns with two 10 SWG (two 10 SWG
parallel winded )**
Core Details : 7/2.5 inch or 43/2.5
Bobbin : Window area 5.2 cm ., thikness -6.7
I tried to Design the same on a paper and i cannot get the similar design Values and got stuck pleas help me (sorry for my Bad English)
My Design as follows
Core Area = 1.52 8 sqrt of (O/P voltage * O/P Current)
Core Area = 1.52 x Sqrt 1000VA (not taken efficiency )
= 48.06 cm^2
TPV = 1/4.44 * CA * Bm * F // Bm ,flux maximum =1.3 ,Fre = 50Hz
Turn Per Volt = 1/ 4.44 * (10^-4 * 48.06) * 1.3 * 50 = .7290volt.
Primary winding current = (Secondary volt * Secondary Current) / primary volt
* 90% efficeancy
Primary winding current : (7.5*133.33) / (250 * .9) = 4.44 amp So 15 SWG wire taken as per table
( but in my real transformer taken 19 SWG how ?)
secondary current is 133 so how the copper wire select i stucked here
primary winding area : .7292 * 250 =180.turns (but in Real transformer has 375 turns wher was i wrong ?)
secondary winding turns = 1.04 * .7292 * 7.5 = 7 turns ( but in real transformer it is 10 swg or with double layer
11 winding)
Please help me to how to desgin are taken the transformer
    \$\begingroup\$ "primary winding area" : you appear to be confusing turns-per-volt with volts-per-turn. For the rest of it, list the formula you're using - THEN substitute your numbers (makes it easier to see where you go wrong), then the result. \$\endgroup\$
    – user16324
    Oct 4, 2016 at 20:13
  • \$\begingroup\$ If it is cheap, they could be under-sizing the wire and running the core beyond what is typically recommended for max flux. \$\endgroup\$
    – MadHatter
    Oct 5, 2016 at 1:41
  • \$\begingroup\$ added the formula \$\endgroup\$
    – Electrone
    Oct 5, 2016 at 2:28
    \$\begingroup\$ I reluctantly upvoted this, even though the formulas are a mess. Please add some structure to your post and read up on how to use LaTeX-style formatting for formulas and equations. \$\endgroup\$
    – pipe
    Oct 5, 2016 at 2:52
    \$\begingroup\$ What is real and unreal transformer? It's pretty complicated to understand, you calculate some parameters and then you ask yourself: but in real transformer....how?. Now, which transformer are you calculating and what is the question? \$\endgroup\$ Oct 5, 2016 at 7:35
I see: you are examing the transformer you bought and your calculations don't match. Volts per turn is 0.7292 V/turn. Let's ask how many turns are required for 250V? Answer is: \$N=\dfrac{250}{0.7292} \approx 343\$. The first mystery is solved.
The real transformer has 375 turns, \$\dfrac{375}{343}\cdot 1.3= 1.42\$, you are lucky, because if you buy from ebay you can get a transformer with \$B_{max}\$ at 1.9 Tesla.
The wires are too thin: maybe you have a diffent table, or they cheated on copper. If you see that the window has a lot of space left, then they cheated. If you see that window is full, then a thicker wire couldn't be used.
