I am trying to pick an inductor for use with switching regulator with switching frequency of 500KHz.
I looked at single inductor manufacturer which has two line up. One saying "Inductors for Decoupling Circuits", and the other saying "Inductors for Power Circuits."
The links to datasheets are below.
[Datasheet] Inductors for Decoupling Circuits
[Datasheet] Inductors for Power Circuits
What are the difference between the two other than the current capacity?
May I use any of them if both fits my current budget?
Those two data sheets make it difficult to compare like with like, as the power inductors have two rated currents (inductance and thermal), whereas the decoupling inductors have a single rated current, and a minimum Q.
In my designs, I have two different applications, both of which require things called inductors. They both require a certain current to be supported while maintaining a minimum inductance.
The first application is in a power supply filter network, where some degree of dissipation in the ferrite at high frequency is positively beneficial. It damps down resonances between components, and absorbs RF signals that I don't want crawling between one module and another. Even those inductors look a bit 'lively' for my tastes, and I usually end up using 'impeders', which have a specified loss at RF.
The second application is energy storage, in dc-dc converters for instance. Here, any power dissipation in the ferrite is a bad thing, it all contributes to overall inefficiency in a converter design.
You can't really optimise designs for either of these applications from a brief datasheet alone. You need a detailed data sheet, and then investigation on a bench with the appropriate test gear. Though using components from the manufacturer's suggested range is a good start.
As you have already observed, the current rating appears to be the main difference. I would argue that "Inductors for Power Circuits" is a description of a particular kind of inductor, while "Inductors for Decoupling Circuits" is a particular application for inductors.
But, as you also conclude, it would be perfectly appropriate to select an inductor that meets your requirements from either category.
