I'm new for PIC32MX and would like to ask the following. Does the oscillator or resonator generates waves when the micros is not programming i.e. is empty Tony
  • \$\begingroup\$ There's no such thing as an "empty" MCU; even an unprogrammed MCU contains opcodes it can potentially execute. \$\endgroup\$ Commented Oct 5, 2016 at 6:35
  • \$\begingroup\$ O'K Ignacio you are right. \$\endgroup\$
    – Tony
    Commented Oct 5, 2016 at 6:47
  • \$\begingroup\$ My question is if the pic32mx is not programmed will external oscillator generates waves? \$\endgroup\$
    – Tony
    Commented Oct 5, 2016 at 6:49
  • \$\begingroup\$ Does the default unprogrammed memory contents translate into halt opcodes? \$\endgroup\$ Commented Oct 5, 2016 at 6:53
  • \$\begingroup\$ No, I'm not sure. I put one unprogrammed pic32m into my pcb and view by oscilloscope if the oscillator (8Mhz) generates waves \$\endgroup\$
    – Tony
    Commented Oct 5, 2016 at 6:59
According to a datasheet, the REGISTER 4-7 comes up with all 1's at power-up, which disables the primary oscillator, so the answer should be no, assuming you are referring to the primary oscillator.
Execution proceeds clocked by the internal RC oscillator until/if another clock source is configured. If the flash memory has been erased, that won't happen.
