I write a structure into EEPRM as follows
typedef struct
   fract32 AmpF; // amplitude fundamental
   fract32 AmpH; // amplitude harmonic
   UINT32 b;
   UINT16 d;
   UINT16 crc;
}CoilBoardAmp_T;
// mechanic angles and salt water angles of coil stored in coil-eeprom
typedef struct
    ChannelData_T     channel[NUM_CHANNELS];
    CoilBoard_T       coilboard;
    CoilBoardAmp_T    coil_h;
    CoilBoardAmp_T    coil_d;
//  UINT32    gCoilSerialNumber;
//  UINT32    gInversSerialNumber;
} Coil_Eeprom_Data_T;
I set that data by a software, which writes to that structure.
The problem is when reading that structure at the first time without writing to it, I read false data.
I need to detect that point. How would I know If the data that is read is false, or how would I know that I read the data without the software.
Add checksum or crc in Coil_Eeprom_Data_T structure. And verify it after reading the data from EEPROM.
