what is meant by low frequency noise in a DC to DC converters that the vendors claim for switching regulators? What is the frequency range?
closed as unclear what you're asking by Daniel Grillo, brhans, pipe, Bence Kaulics, Dave Tweed Oct 11 '16 at 22:41
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Can you reference a specific example? It might also be useful to understand something about your application (are you designing an audio product, or struggling with some cruft you bought on ebay for 0.$?) \$\endgroup\$ – Sean Houlihane Oct 6 '16 at 13:05
Under light load, certain regulators can enter PFM mode which consists of varying the frequency of a pulse. If the load is light enough, the regulator will only need to supply a few (comparatively) pulses per second. This can induce low frequency noise though I'd imagine the frequency is load dependent.
The Microchip TC105 for example is a buck converter which switches between PWM and PFM mode for light load conditions - defined as duty cycles less than 10%.
