I've read various posts regarding differential voltage measurements. I'm confused as to why it seems virtually impossible to measure differential voltages that are high relative to ground (like differential between 251V vs 249V) and feed that value to a microcontroller. The challenge appears to be due to the fact that the A/D chips have limits of the voltage you can apply relative to the Vcc. It becomes more complicated if you want to multiplex various differential measurements to the microcontroller. I've seen various discussions on this topic and no compelling methods, but every handheld battery powered digital multimeter appears capable of performing the function with the exception of the data transfer to the microcontroller. Does anyone know how the multimeters acheive this?
  • \$\begingroup\$ was this for DC current sensing or AC? They have DC HV current sense IC's for this range \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 18 '17 at 22:49
If you have a floating supply (battery) then there are no absolute or earth ground stresses of offsets or common mode voltage issues to deal with.
The usual limitation is that the signal must be inside the supply voltage rails or even inside 2V away from the rails. Some are design to work a bit below ground (PNP inputs) or above V+ rail somewhat (NPN inputs) but not likely 250V above the supply voltage to the chip. ( but possible at higher expense.)
It is possible however to design a custom solution to perform this task in a ground referenced system or use a positive supply reference with a small negative rail, or AC couple or attenuate within the supply range , then amplify the difference. There is one chip I know with ADC with (DC isolated) differential inputs for high voltage measurements.
Also here is a Diff Amp with +/-270V CM linear range and +/-500V CM protected range. www.analog.com/media/en/technical-documentation/data-sheets/AD629.pdf
This works due to 20:1 reduction of input signals with precision matched R's. 77 dB minimum CMRR @ 500 Hz enter image description here
| improve this answer | |
  • \$\begingroup\$ could you provide a link or part number to the chip you referenced? \$\endgroup\$ – Dsel Feb 18 '17 at 22:07
  • \$\begingroup\$ ok I'll include in answer \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 18 '17 at 22:21
  • \$\begingroup\$ was this for DC current sensing or AC? They have DC HV current sense IC's for this range. Can you use galvanic isolation solutions? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 18 '17 at 22:50
To ground-reference and subtract two signals that are very close to each other is difficult because you are basically subtracting two large numbers to get a much smaller difference.
If you measure a voltage of 251V with an accuracy of 0.1% and a voltage of 249V with an accuracy of 0.1% the difference could be in error by as much as +/-0.5V, which is an error of +/-25% (of the difference). If your object is, for example, to balance battery cell voltages that's nowhere near good enough.
Now if you can subtract the two voltages before either shifting to ground or using a galvanically isolated circuit it becomes relatively easy to get high accuracy.
Multimeters are galvanically isolated. They don't know what the voltage is on their inputs with respect to ground- all they know is the difference between the input terminals (this has some complications with AC inputs). You can do the same thing as a voltmeter by (for example) using a DC-DC converter to power a circuit sitting on the 249V input and then subtract the 251V and transmit the difference to ground. It could be digitized and sent serially, or level-shifted with an analog current source, for example.
In fact, using that method it's possible to measure voltage differences that are millivolts or even lower, even when sitting on top of hundreds of volts- or even much, much higher voltages.
  • \$\begingroup\$ Thanks. When you say "sitting on" do you mean the 249V is powering the DC-DC converter, which is powering the circuit, or can the DC-DC converter be powered from an independent source? All the differential A/Ds I've looked at seem to require the inputs to be less than the Vcc for the chip. \$\endgroup\$ – P.J. Smith Oct 8 '16 at 5:19
  • \$\begingroup\$ An isolated DC-DC converter could, say, be powered from a 5V source (say connected to your microcontroller ground) and one side of the output connected to the 249V input, so the ADC would be at 249V ADC GND/254V ADC Vcc with respect to ground. There are other possible approaches. Some kind of input protection would probably be required. \$\endgroup\$ – Spehro Pefhany Oct 8 '16 at 5:42
