I know it is common to generate sine waves via Direct Digital Synthesis (DDS). What I would like to know is if it is possible to generate a modulated signal via DDS and if so what would be a practical maximum frequency to do so?
Is this a technique being use in practice for emission modes like A3E or F3E?
DDS will generate just about anything.
Max practical frequency depends mainly on your wallet size.
Processing power is obviously the issue.
Amateurs can do 100's of MHz and mayhaps GHz.
As you approach the clocking frequency of your system you become increasingly able to create only a single frequency square wave at clock frequency :-). ie you need enough "bits" to both populate a sine wave at multiple levels and to run the frequency generation logic.
I'd "mentate" that A3E and F3E (SSB, FM) would be "easy enough" using the basic technique but frequency would be lower for an IC of given gate speed, given the complexity of the waveforms needed. ie using the technology in the AD ICs below you are probably not going to get much beyond 100 MHZ. You can do the arithmetic to look at what sort of bit manipulation is needed to form signals of the type required. (It's all just sine waves in the end :-) ).
Using "Super Nyquist techniques" (clove of garlic worn near heart, bury at cross roads at midnight) the ICs below can be pushed to an indefinite multiple of their primary frequency range. See eg AD AN-939: Super-Nyquist Operation of the AD9912 Yields a High RF Output
Commercial 40 GHz DDS - really DDS + upconversion
The Analog Devices AD9910 clocks at 1 GHZ and can produce output to 400 MHz. About $45/1000
AD say:
  • Cheaper AD9956 notes when used with an external VCO, enables the synthesis of digitally programmable, frequency-agile analog output sinusoidal waveforms up to 2.7 GHz.
  • The AD9910 and AD9912 high speed DDS chips can both be clocked at 1GHz, allowing for output signals up to 400MHz in the baseband. The quality of the DDS output signal depends to a high degree on the quality of the DDS reference clock signal. Therefore a lot of attention has to go the 1GHz reference clock in order to make the DDS a success. The following criteria are important to the reference clock:
http://martein.home.xs4all.nl/pa3ake/hmode/img/dds_1ghz_narrow.jpg
From data sheet (too much to format prettily - feel free :-) )
1 GSPS internal clock speed (up to 400 MHz analog output) Integrated 1 GSPS, 14-bit DAC 0.23 Hz or better frequency resolution Phase noise ≤ −125 dBc/Hz @ 1 kHz offset (400 MHz carrier) Excellent dynamic performance with
80 dB narrow-band SFDR
Serial input/output (I/O) control Automatic linear or arbitrary frequency, phase, and amplitude sweep capability 8 frequency and phase offset profiles Sin(x)/(x) correction (inverse sinc filter) 1.8 V and 3.3 V power supplies Software and hardware controlled power-down 100-lead TQFP_EP package Integrated 1024 word × 32-bit RAM PLL REFCLK multiplier Parallel datapath interface Internal oscillator can be driven by a single crystal Phase modulation capability Amplitude modulation capability Multichip synchronization
You'd think they didn't know how to lay out PCBs, if you didn't know better ... :-) !
Digikey's stable](http://search.digikey.com/us/en/cat/integrated-circuits-[ics/interface-direct-digital-synthesis-dds/2556393?k=dds)
Digikey's champion - 2.7 GHz AD9956
$34/1 in stock.
PRODUCT OVERVIEW
The AD9956 is Analog Devices’ newest AgileRF synthesizer.
The device is comprised of DDS and PLL circuitry.
The DDS features a 14-bit DAC operating at up to 400 MSPS and a 48-bit frequency tuning word (FTW). The PLL circuitry includes a phase frequency detector with scaleable 200 MHz inputs
(divider inputs operate up to 655 MHz) and digital control over the charge pump current.
The device also includes a 655 MHz CML-mode PECL-compliant driver with programmable slew rates.
The AD9956 uses advanced DDS technology, an internal high speed, high performance DAC, and an advanced phase
frequency detector/charge pump combination, which,
  • when used with an external VCO, enables the synthesis of digitally programmable, frequency-agile analog output sinusoidal waveforms up to 2.7 GHz.
The AD9956 is designed to provide fast frequency hopping and fine tuning resolution (48-bit frequency tuning word). Information is loaded into the AD9956 via a
serial I/O port that has a device write-speed of 25 Mb/s. The AD9956 DDS block also supports a user-defined linear sweep mode of operation.
The AD9956 is specified to operate over the extended
automotive range of −40°C to +125°C.
Practical DDS incarnations with AVR:
