What kind of jumper wires should I get for electronics and a breadboard? There are female to female, male to female, female to female with headers. I don't know what to get. Just hookup wire?
    \$\begingroup\$ I use #22 or 24 solid hookup wire (but the fancy jumper things weren't invented when I first used a plastic breadboard). \$\endgroup\$ Oct 9, 2016 at 19:52
  • \$\begingroup\$ @PeterBennett What do you do when you need a female connection? \$\endgroup\$
    – johnny
    Oct 9, 2016 at 19:54
  • \$\begingroup\$ If I needed a female connector, I'd probably just take a couple of turns arond the pim with my solid wire. \$\endgroup\$ Oct 9, 2016 at 20:32
From my experience, you should get all three types. Most of the time you will be using male-to-male and male-to-female.
Since using wires for breadboard connections can create quite a mess on the breadboard, I would also suggest getting these:
Jumper wire
  • \$\begingroup\$ Do you plug header pins right into the breadboard? \$\endgroup\$
    – johnny
    Oct 9, 2016 at 19:43
  • \$\begingroup\$ Yes, I usually plug header pins directly into the breadboard, whenever it is possible. You cannot plug 2-row headers directly (happens quite a lot), and that is when you can use male-to-female wires. \$\endgroup\$ Oct 9, 2016 at 19:48
  • \$\begingroup\$ what is the name of the wires in the image? \$\endgroup\$ Dec 23, 2022 at 13:41
The standard solid strand breadboards wires are nice when making a nice clean circuit however they break quickly: http://tinyurl.com/z482nme
These are really nice in that they are made out of stranded wire with molded ends. They rarely break and are really easy to work with however they make a circuit messy fast: http://tinyurl.com/ha94t8e
Female/Female aren't very common. You mostly needs these for connecting male header pins on breakout boards not necesarrily bread boards but they are still nice to have around: http://tinyurl.com/jhwwkpa
My advice is to buy all 3 of the above. It may look like a lot but it doesn't take long for them to get lost, melted, broken, etc.
