I'm trying to solve this second order differential equation for a RLC series circuit using Laplace Transform. The Laplace transform of the equation is as follows:
$$I(s) = \frac{E}{s^2+ \frac{R}{L}s + \frac{1}{LC}}$$
I'm having trouble trying to bring it back to the time domain. Should I be using partial fractions with quadratic factors or there a easier method to go abut this? And is the damping factor to be considered? If it is, how do I go about dealing with it?
5 Answers 5
I will give it a try:
let \$D = \frac{R}{2L}\$ and \$\omega^2 = \frac{1}{LC}\$
for \$D^2 \not= \omega^2\$:
$$I(s) = \frac{E}{s^2+ 2Ds + \omega^2}=$$
$$=\frac{E}{\left(s+\left(-D+\sqrt{D^2 - \omega^2}\right)\right)\left(s+\left(-D-\sqrt{D^2 - \omega^2}\right)\right)} =$$ (partial fraction) $$ =\frac{E}{-2\sqrt{D^2 - \omega^2}} \frac{1}{\left(s+\left(-D+\sqrt{D^2 - \omega^2}\right)\right)} + \frac{E}{-2\sqrt{D^2 - \omega^2}} \frac{1}{\left(s+\left(-D-\sqrt{D^2 - \omega^2}\right)\right)}$$
Looking up the Laplace transform $$ \mathcal{L}^{-1}\left[\frac{1}{s+a}\right] = e^{-at} $$
$$ \mathcal{L}^{-1}[I(s)] = \frac{E}{-2\sqrt{D^2 - \omega^2}} \left( e^{t\left(-D+\sqrt{D^2 - \omega^2}\right)} - e^{t\left(-D-\sqrt{D^2 - \omega^2}\right)} \right)$$
for \$ D^2 = \omega^2\$:
$$I(s) = \frac{E}{s^2+ 2Ds + D^2}=\frac{E}{(s+D)^2}$$
Looking up the Laplace transform $$ \mathcal{L}^{-1}\left[\frac{1}{(s+a)^{n+1}}\right] = \frac{t^n}{n!} e^{-at} $$
$$ \mathcal{L}^{-1}[I(s)] = E \cdot t \cdot e^{-D t}$$
  • \$\begingroup\$ Hmm. It looks right, but why do I get the sense that something isn't right for the D^2 > w^2 case? Maybe I'm just expecting a particular solution to oscillate in all cases, and my intuition is wrong. If your math is right, then there's also a special case for D^2 = w^2 (critically damped) of the form t*e^(-at) \$\endgroup\$
    – Jason S
    Feb 7, 2012 at 15:07
    \$\begingroup\$ @JasonS Indeed; if the oscillating period is big enough, the exponential function should be predominant and cause a discharging exponential function...if I'm not wrong \$\endgroup\$
    – clabacchio
    Feb 7, 2012 at 15:44
  • \$\begingroup\$ I expanded on the case D^2 = w^2. \$\endgroup\$
    – PetPaulsen
    Feb 7, 2012 at 16:17
  • \$\begingroup\$ @PetPaulsen- Thanks a lot PetPaulsen, this was a really good way of showing me how to do it. The problem I have is that when I worked it out, I got the A term in D^2 > w^2 should be positive, not negative. \$\endgroup\$
    – D Brown
    Feb 8, 2012 at 23:12
Massage it into a form that looks like something in this table. You should come up with something like sine or cosine whose frequency depends on L and C, and multiplied by a damping function that looks like a decaying exponential depending on R, L, and C intuitively.
  • \$\begingroup\$ @vicatcu- Thanks for the link to the Laplace Tables and the advice and the damping function :) \$\endgroup\$
    – D Brown
    Feb 8, 2012 at 23:15
You have a second order function at the denominator, that can be solved to give two factors in the form \$(s-a)(s-b)\$. This is the equivalent of
$$ {1 \over (s-a)} \cdot {1 \over (s-b)} $$
This is a multiplication of two functions, that, for Laplace transform as well as Fourier transform, gives a convolution of functions when anti-transformed. So you can obtain the convolution of two functions in the time domain, and you can manipulate that to obtain a nicer function.
That's the way to go, if you have to use the Laplace transform. (If you don't have to use the Laplace transform, look the answer up. :-)
$$ ax^2+bx=a \left[ (x+\frac{b}{2a})^2 -(\frac{b}{2a}) \right] $$ so we can write : $$ s^2+\frac{R}{L}s=(s+\frac{R}{2L})^2 - (\frac{R}{2L})^2 $$ $$ I(s)=\frac{E}{s^2+\frac{R}{L}s+\frac{1}{LC} }=\frac{E}{(s+\frac{R}{2L})^2 +\frac{1}{LC}- (\frac{R}{2L})^2} $$ we know: $$ \mathcal{L} \left[ e^{-at}sin(wt) \right] = \frac{w}{(s+a)^2+w^2}$$ so we have : $$ i(t)=\frac{E}{\sqrt{\frac{1}{LC}-(\frac{R}{2L})^2}} e^{\frac{-R}{2L}t} . sin(\sqrt{\frac{1}{LC}-(\frac{R}{2L})^2}\space.t)$$
