I want to make a new project with AT91SAM9260 in Atmel Studio 7 but it doesn't support the device.
My question is:
Did Atmel make a C library with this device to Atmel Studio 7? If no, what version does this device have ?
  • \$\begingroup\$ In my version of Atmel Studio 7 (7.0.1006) I see this device (File -> New -> Atmel Start Project: Select device and go on). \$\endgroup\$
    – mic
    Commented Oct 10, 2016 at 15:34
  • \$\begingroup\$ Aw, sorry not this, I wanted to write AT91SAM9260 \$\endgroup\$
    – Sewek
    Commented Oct 10, 2016 at 16:10
  • \$\begingroup\$ I think it should support it. If I remember correctly, when you install Atmel Studio it will ask you what you want it to support: 8-bit AVR, 32-bit AVR, and SMART ARM. Do you remember checking the last one? \$\endgroup\$ Commented Oct 10, 2016 at 16:33
  • \$\begingroup\$ @DigitalNinja I checket all \$\endgroup\$
    – Sewek
    Commented Oct 10, 2016 at 16:48
  • \$\begingroup\$ @Sewek It looks like it is not supported, it's not in the list of devices. atmel.com/tools/atmelstudio.aspx?tab=devices. But if you read through the documentation for the device, it will probably help you get setup. You'll just need some other ARM toolchain. yagarto.org \$\endgroup\$ Commented Oct 10, 2016 at 17:02
There is a library made by ATMEL. I looked it up from KEIL'S uVision IDE and this webpage. I also could not find support for ATMEL Studio 7.
