With these antennas; how does the signal flow through the glass?
Is it also possible across other bands; like 2.4GHz Wi-Fi signals?
Glass-Mount
Specifically tuned for the 4G NextG / 3G spectrum for optimum reception performance. Operates at 5db gain. Suits: All handsfree car kits / cradles that require external antennas.
GSM 900MHz / 1,800MHz
3G 2,100MHz
NextG 850MHz
FME Connection
Whip 1 Gain 5dB
Cable Length 5m
  • \$\begingroup\$ The same way the light gets through the window. \$\endgroup\$ – pjc50 Oct 10 '16 at 19:01
  • \$\begingroup\$ No. It's near field coupling at the base of the antenna pod. \$\endgroup\$ – Janka Oct 10 '16 at 19:29
  • \$\begingroup\$ For lower frequencies, magnetic coupling is probably more efficient than that very small-value capacitor with a wide plate spacing (through the glass). \$\endgroup\$ – Richard Crowley Oct 10 '16 at 20:15
The glass acts like the dielectric of a capacitor, with the plates being the structures stuck on opposite sides of the glass, I think...
| improve this answer | |
  • \$\begingroup\$ No doubts. That is exactly how they work. \$\endgroup\$ – JRE Oct 10 '16 at 16:03
