I'm very new to electronics engineering, so please forgive me if I'm asking stupid questions!
I'm working on a device which is based around an Atmel Sam L21 ARM MCU with 4 UART devices attached (amongst other things), and powered by a couple of AA batteries. I've attached a very crude diagram of how things are connected, but I have the following questions:
  • Which pins are used to power the MCU? I assume it's either VDDCORE or VDDIN and a GND pin at the top.
  • Do I need to add decoupling capacitors between the power supply and the MCU?
  • Are the peripheral devices powered directly from the batteries, or through the VDDIO pins on the MCU?
  • Again, do these need decoupling capacitors between the peripherals and the MCU?
I've read a couple of really detailed posts on here that relate to how and when to use decoupling capacitors, and I'm planning on reading through them again today to get my head around it all, but if someone could help me out with this power supply stuff, I'd be hugely appreciative!
crude circuit diagram - feel free to modify
    \$\begingroup\$ Have you had a chance to read the datasheet yet? \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 11 '16 at 10:03
  • \$\begingroup\$ I have actually. I found this, but still terribly confused if I'm honest! http://i.imgur.com/Ed3VtR3.png \$\endgroup\$ – Andy Mills Oct 11 '16 at 10:07
  • \$\begingroup\$ It might be worth having a go with a development board before trying to implement a design from scratch. When you do get to that part most chips have a refference schematic you can start from. \$\endgroup\$ – Hugoagogo Oct 11 '16 at 10:08
  • \$\begingroup\$ Also you can probably steal most of the BOM directly from the dev board. Regarding decoupling caps, it is standard practice to always put one as close to each supply pin as possible, on every integrated circuit. Typically a standard 100nF cap unless the datasheet says otherwise. In your case, the manufacturer was kind enough to provide recommended values so you can just copy/paste their design. \$\endgroup\$ – Lundin Oct 11 '16 at 11:15
On the chance that this is a serious question and not just trolling, electronic devices come with things called datasheets. This is the industry-wide name for the document that gives all the specifications of a device. The datasheet of a microcontroller is often over 100 pages, and can reference other documents. All information needed to design a part into a circuit and to use it properly should ultimately be available in the datasheet or whatever other documents it might reference.
The pinout is absolutely something that will be in the datasheet.
Again, its not clear if this is trolling. If you know enough to know there are such things as decoupling capacitors, then it's hard to understand how you don't know that they would be required here.
That's up to you. Generally you'd power peripheral devices directly from the same power supply. However, in some cases where the device takes very little power and you want to switch it on and off, you can power it from a output pin. I've actually done this.
However, if you have to ask, then just power each device from the power supply directly.
This is a stupid question, since it was previously asked, and the answer should be obvious anyway. In addition to this datasheet, you also need to employ something we call a brain. Even a minimal search here would have yielded plenty of explanations, such as "How do I know where I need decoupling capacitors?".
