This question already has an answer here:
I am using a 555 IC to produce a sound in a small 8 ohm speaker. It works just fine, but the square wave sounds rather harsh. I am wondering if there is a simple way to round out the corners to make it sound better. All the circuits I have found online are rather complex. It seems to me that a simple RC circuit should do the trick, but I have not been able to figure out how to position it.
Any help would be greatly appreciated.
marked as duplicate by Daniel Grillo, Dave Tweed Oct 11 '16 at 22:41
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ Why the modulation tag? \$\endgroup\$ – pipe Oct 11 '16 at 14:26
  • \$\begingroup\$ simple at one 1 tone, wont work over a range \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Oct 11 '16 at 14:33
  • \$\begingroup\$ Modulation tag removed. I thought it was appropriate. My mistake. \$\endgroup\$ – Fed Oct 11 '16 at 15:30
Simple, something like this:
You will have to experiment with the values of R1 and C1, their optimum will depend on the frequency you're making with the NE555.
This will make the signal less loud
  • \$\begingroup\$ Great, I'll work with that! \$\endgroup\$ – Fed Oct 11 '16 at 15:31
