I'm trying to add the MIPS assembly command BGTZ to the following circuit: enter image description here
I know that BGTZ takes the register value and sees if it's greater than 0. If it's greater it branches to the target. Can I compare the register value to a constant zero with an or gate?
EDIT: corrected BGTZ
  • \$\begingroup\$ BGTZ stands for Branch on Greater Than Zero, and applies to a single register. You are apparently thinking of BEQ. \$\endgroup\$ Oct 15, 2016 at 18:05
  • \$\begingroup\$ @WhatRoughBeast oh shoot you're right! So I can compare the register value to 0 and if it's greater have the branch trigger? \$\endgroup\$
    – Raviga
    Oct 15, 2016 at 19:38
  • \$\begingroup\$ Sure. As long as you can find a command which does that. \$\endgroup\$ Oct 16, 2016 at 0:04
Here's what I did to add BGTZ to the circuit: enter image description here
