I have a problem where I have a 60 Hz sinusoidal power signal with an amplitude of 14.14 V through a full bridge rectifier with constant voltage modelled diodes (\$V_D = 0.7V\$)
The load current is \$30 mA\$ on average. I need to find the ripple voltage \$V_r\$, average DC output \$v_{outavg}\$, peak inverse voltage experienced by the diodes \$PIV\$, the peak and average currents through the diodes \$i_{dmax}\$ and \$i_{davg}\$. The circuit uses a \$250 \mu F \$ capacitor as a filter capacitor.
Since we aren't given the ripple voltage and the resistor are unknown i'm not sure how to proceed.
I have the input: \$V_1 = 14.14 V\$
Peak output: \$ V_{peak} = V_1 - 2V_d = 14.14 - 1.4 = 12.24V\$
Peak inverse voltage :\$PIV = V_1 - V_D = 14.14 - .7 = 13.44 V\$
$$i_{davg} = i_{loadavg} (1 + \pi\sqrt\frac{V_{peak}}{(2V_r)}) = 30 mA (1 + \pi\sqrt\frac{14.14}{(2V_r)})$$
$$i_{dmax} = i_{loadavg} (1 + 2\pi\sqrt\frac{V_{peak}}{(2V_r)}) = 30 mA (1 + 2\pi\sqrt\frac{14.14}{(2V_r)})$$
$$V_r = \frac{V_1 - 2V_D}{2fRC} = \frac{14.14 - 1.4}{2 \cdot 60 \cdot R \cdot (250\times10^{-6})}$$
How do I solve for \$V_r\$ without knowing the resistor? And where else do I go from here? Is what I have correct so far?
