I am trying to get a basic understanding of how VGA port interfacing works.I have started reading SPARTAN 3 VGA Port Interface. I get the function of horizontal and vertical syncs, and the subsequent clock requirements, but I still don't understand the following few lines :
A separate counter tracks the vertical timing. The vertical-sync counter increments with each HS pulse and decoded values generate the VS signal. This counter tracks the current display row. These two continuously running counters form the address into a video display buffer. For example, the on-board DDR SDRAM provides an ideal display buffer. This counter tracks the current display row. These two continuously running counters form the address into a video display buffer. For example, the on-board DDR SDRAM provides an ideal display buffer.
What does it mean by an ideal display buffer? Say, I were streaming "live" video, it would first be stored in the on-board DDR SDRAM? How do the two continuously running counters form the address (is this the address where each pixel's RGB data is stored) into a video display buffer?
