Sir,
Whenever i simulate my vhdl code of 4 bit counter in Xilinx vivado 2015.2, i get the error message like following.
ERROR: [VRFC 10-724] found '0' definitions of operator "+", cannot determine exact overloaded matching definition for "+"
My vhdl code is
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity my_count is
Port ( clk : in STD_LOGIC;
       clr : in STD_LOGIC;
       y : out STD_LOGIC_VECTOR (3 downto 0));
end my_count;
architecture Behavioral of my_count is
begin
    process(clk,clr)
    variable temp: std_logic_vector(3 downto 0):="0000";
    begin
        if(clr='1') then
            temp := "0000";
        elsif(clk='1' and clk'event) then
            temp := temp + 1;
        end if;
        y <= temp;
    end process;
end Behavioral;
test bench is
library IEEE;
entity my_count_tb is
    --  Port ( );
end my_count_tb;
architecture Behavioral of my_count_tb is
component my_count
    port(clk,clr: in std_logic;
         y: out std_logic_vector(3 downto 0));
end component;
signal clr,clk: std_logic;
signal y: std_logic_vector(3 downto 0);
begin
    process
    begin
        clk <=not clk after 5ns;
    end process;
end Behavioral;
please help me to solve this error
    \$\begingroup\$ temp := std_logic_vector(unsigned(temp) + 1); \$\endgroup\$ Oct 17, 2016 at 9:43
Use the type system instead of fighting it.
Any time you see an uncomfortable double type conversion, especially to another type and immediately back again, like
that is fighting the type system, and probably points to a more or less serious mistake in the design.
Instead, think about this:
You want to count - so your data is some form of number, not just a bag of bits.
What range do you want to count? That's not clear from your question, so I'll guess 0 to 15, eliminating negative numbers, covering the 4 bits of output data.
There are 2 obvious choices :
variable temp: natural range 0 to 15 := 0;
variable temp: unsigned(3 downto 0) := "0000";
You are already using the correct numeric_std library for the latter.
Now there will be a suitable "+" operator visible.
What's missing so far is a connection to the output port y.
If you are forced by ridiculous coding standards or a huge existing project to keep all ports std_logic_vector you'll need a type conversion.
y <= std_logic_vector(temp); -- for unsigned temp
y <= std_logic_vector(to_unsigned(temp,y'range)); -- for natural temp
If you are allowed to fix a broken design, consider what y means in the larger context : if it's an unsigned number such as a memory address, use the right type in the port declaration, then the simplest y <= temp; is the correct approach.
Look here. @A-Kieffer says
In VHDL you cannot use arithmetic operators with std_logic_vector.
  • \$\begingroup\$ this error occuring again even i change std_logic_vector to bit_vector. \$\endgroup\$
    – Varun
    Oct 17, 2016 at 8:25
  • \$\begingroup\$ please give the correct code with the test bench \$\endgroup\$
    – Varun
    Oct 17, 2016 at 8:31
As stated here.
"You can't increment std_logic directly, you need to convert it to unsigned and the result back to std_logic_vector using the numeric_std package."
@apalopohapa also mentioned it in his comment:
"temp := std_logic_vector(unsigned(temp) + 1);"
begin
    process(clk,clr)
    variable temp: std_logic_vector(3 downto 0) := "0000";
    begin
        if(clr='1') then
            temp := "0000";
        end if;
        y <= temp;
    end process;
end Behavioral;
  • \$\begingroup\$ ERROR: [VRFC 10-91] unsigned is not declared ERROR: [VRFC 10-1083] near std_logic_vector ; type conversion expression type cannot be determined uniquely \$\endgroup\$
    – Varun
    Oct 17, 2016 at 10:25
  • \$\begingroup\$ errors still present in simulation \$\endgroup\$
    – Varun
    Oct 17, 2016 at 10:26
  • \$\begingroup\$ please help me to find the test bench for the following 4 bit counter code.my test bench is not working \$\endgroup\$
    – Varun
    Oct 17, 2016 at 12:17
  • \$\begingroup\$ library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity my_count is Port ( clr : in STD_LOGIC; clk : in STD_LOGIC; y : out STD_LOGIC_VECTOR (3 downto 0)); end my_count; architecture Behavioral of my_count is begin process(clk,clr) variable temp: std_logic_vector(3 downto 0) := "0000"; begin if(clr='1') then temp := "0000"; elsif(clk='1' and clk'event) then temp := std_logic_vector(unsigned(temp) + 1); end if; y <= temp; end process; end Behavioral; \$\endgroup\$
    – Varun
    Oct 17, 2016 at 12:19
  • \$\begingroup\$ What's the error? \$\endgroup\$
    – user103993
    Oct 17, 2016 at 12:35
