I recently posted a thread about using a coin cell to power an electronics project that features an SD card (here). The problem at hand is that the SD card will pull high current during read/write operations, much higher than a coin cell can handle. However, the fact that the SD card pulls very little current outside of read/write operations leads me to believe that I can use a capacitor charge/discharge circuit for supplying higher power to SD cards when it is needed. I'm hoping I can get some verification regarding my design.Proposed circuit schematic.
After doing some rough hand calculations, I've calculated that I will need to write to my SD card every 2 seconds. The amount of data that will need to be written is 512 bytes. Referencing a previous post I made, the user jonk provided this picture:
I will be using an 8Mhz clock, along with a 3.3V power supply, thus I calculated an SD card write speed of 4 Mb/s. Using this clock rate on my 512 bytes, that comes out to a write time of 0.000128 seconds. Because I assume there is overhead involved, I rounded this up to a 'hopefully generous' 1ms.
So my calculations suggest that I can charge the capacitor for up to 2 seconds, and then can discharge it at a rate such that an appropriate voltage is sustained for at least 1ms.
Referring to my circuit design, I am using a 3.3V coin cell (CR2032) whose voltage is regulated by a 120mA switched cap regulator. This regulator acts as the main power source for other components that can consume 6mA current continuous. Note that I am open to selecting a different coin cell that can provide a higher continuous current. Also note that I realize that the 6mA by itself is higher than the rated continuous current of a CR2032 coin cell, however, I am willing to lose cell capacity for higher current. While I'm ok with 6mA, I am not okay with an additional 30mA pulsating SD load.
I've selected a 3.3K resistor to limit the capacitor charging current to 1mA max, and I've select a 180uF capacitor given that it seems to charge to 3.3V in the allotted 2 seconds.
I've estimated that the SD card will pull 30mA during write operations, the 180uF capacitor appears to be able to hold enough charge to sustain a 30mA current for 1ms. I did a quick simulation in SPICE and after 1ms of capacitor discharge, the voltage dropped to 2.9V which is still acceptable for powering an SD card. I modeled my SD card as a 100 ohm resistor that would switch on every 2 seconds for a duration of 1ms.
So my questions:
How much overhead is involved when writing to an SD card (FAT32 file system)? Would my estimate of a 1ms write time cover all the overhead required to write to a text file on an SD card?
For my application, is it fair to model an SD card as a resistor that switches on periodically?
Does it appear that I may be overlooking anything?
  • \$\begingroup\$ Quick question. You say your clock speed is \$8\:\textrm{MHz}\$. I assume that is your MCU instruction clock rate. You presume, from reading the diagram, that this means you can achieve half that as a bit rate to the SD card. Why? Do you have a hardware peripheral on your MCU that supports SD cards directly? I think you need to first explain exactly how you are going to achieve half your MCU clock rate into the SD card. \$\endgroup\$
    – jonk
    Commented Oct 17, 2016 at 21:08
  • \$\begingroup\$ I should also add that when performing a write, there is a busy delay while the SD card performs the write and completes it. What information have you collected about how long this is likely to be -- assuming the default mode of operation. \$\endgroup\$
    – jonk
    Commented Oct 17, 2016 at 21:12
  • \$\begingroup\$ @jonk Great question that I've probably not put enough thought into. I plan on using SPI for communications between my Atmega328p (via Arduino) and SD card. Referencing this webpage (arduino.cc/en/Reference/SPISetClockDivider), I will likely set the SPI clock to a divider of 2 such that it operate at 4Mhz. And because that would be at 4Mhz 1 bit at a time, my write speed would be slower than the original 4Mb/s I stated. Thanks for this! \$\endgroup\$
    – Izzo
    Commented Oct 17, 2016 at 21:19
    \$\begingroup\$ Assume NOTHING about the library. You need to find out what it does by measuring -- or go read the code for it and find out. Do you have a way of monitoring the dialog (logic analyzer?) I'm going to add an answer to start and fill it out as things proceed a bit, rather than "chatting" here. \$\endgroup\$
    – jonk
    Commented Oct 17, 2016 at 21:29
    \$\begingroup\$ A good design has specs for all inputs/outputs, size, functions and a cost target for both R&D and BOM. Then you figure out if it's possible by calculations & tests , then how to do it better by iteration of specs. If you do not write specs, then how do know if your design is perfect? It is perfect when it meets or exceeds all the specs including R&D costs. trial and error with a coin cell and RC filter is not the way. \$\endgroup\$ Commented Oct 17, 2016 at 21:53
I think you've jumped far too quickly into the design stage of the electronics portion that you now do understand better and have given short shrift (by waving hands in the air) to studying the SD card specification. You should shift gears and set aside the easier part (which is the electronics that simply flows out of the information you still need to collect) and delve more deeply into the SD card portion of this.
Study the specification. Look, for example, at 4.6.2.2. What times do you see there? Have you read 4.4 and looked at going into energy saving modes for the SD card? If you are doing a write, will you also need to do a read prior to that? (Are you partially modifying a block?)
If you are planning on using the Arduino library without understanding the code that was written for it and how it relates to the SD card specification, first hand, then you need a way to make measurements with the library so that you can observe what it actually does do and what the power requirements look like.
In the best of circumstances, you should at least read the SD card specification for the relevant parts of what you are trying to do. Not necessarily because you are going to write code -- it seems you want to use the library code -- but because you need to understand the specification itself to know what your library must contend with. This allows you to anticipate circumstances that 1000 measurements of actual tests won't tell you about. You can test all day long with the library and never trip up on some detail. So you'll just go and assume, figuring that since you haven't seen a problem, there won't be a problem later on.
This is the point of reading the SD card specification, as a matter of independently informing yourself and not just blindly using a library. Sure, the author probably read the specification and does know these things. But when they create the library, they don't document everything they've learned. They just write the library. You have the job, separately, of knowing the specification and the reach of it in cases where you can't actually test. (It's impossible for you to go get every SD card ever manufactured. But if you read the specification, you can make sure that you cover all the conforming cards and situations, at least.)
There's no escaping your education here. You can focus on what you care about: Write, Power Saving Mode, Read (perhaps), and anything else you can think up that you might do (or you think the library actually will do.) But to design the electronics which is responsible for maintaining sufficient power, you need to know just how long the worst case might be. And you need to know that, firmly, in your own head and to to exactly why you know what you know. You could be able to rattle it off almost as fast as you can talk.
Once you have a full handle on that part, and assuming your library does its job as it should, then you can make some estimates. But really, the electronics part of this is almost trivial. Falls out so easy. The difficulty is all the rest here and making sure you know what the worst case might be. With that, the electronics design just falls out.
For example, from Section 4.6.2.2:
For a Standard Capacity SD Memory Card, the times after which a timeout condition for write operations occurs are (card independent) either 100 times longer than the typical program times for these operations given below or 250 ms (the lower of the two).
and,
While the card should try to maintain that busy indication of write operation does not exceed 250ms in the case of SDXC card, if the card is not possible to maintain operations with 250ms busy, the card can indicate write busy up to 500ms including single and multiple block write in the following scenarios:
  • a) The last busy in any write operation up to 500ms including single and multiple block write.
  • b) When multiple block write is stopped by CMD12, the busy from the response of CMD12 is up to 500ms.
  • c) When multiple block write is stopped by CMD23, the busy after the last data block is up to 500ms.
  • d) Busy indication at block gap in multiple block write is up to 250ms except a following case. When the card executes consecutive two blocks write (2*512Bytes) and it spans across the physical block boundary, the busy after the each block can be indicated up to 500ms.
Especially regardless of the above definition, a speed class writing mode specified by CMD20 shall keep write busy up to 250ms in any case until the end of speed class write is indicated.
Or this, as one of their final notes:
It is strongly recommended for hosts to implement more than 500ms timeout value even if the card indicates the 250ms maximum busy length.
What do you make of all the above, for example?
Here's another interesting note (to me) that seems to relate a corner case to your desire for 512 byte writes. From Section 4.4:
For example, in the case that a host with 512 Bytes of data buffer would like to transfer data to a card with 1 KByte write blocks. So, to preserve a continuous data transfer, from the card's point of view, the clock to the card shall be stopped after the first 512 Bytes. Then the host will fill its internal buffer with another 512 Bytes. After the second half of the write block is ready in the host, it will continue the data transfer to the card by re-starting the clock supply. In such a way, the card does not recognize any interruptions in the data transfer.
From this, I have learned that not all SD cards use 512 byte blocks. That's interesting. It makes me wonder if the Arduino library supports this mode of lower power operation. And it makes me wonder if you should perhaps consider writing your own code, as this could actually be helpful when performing writes and wanting to lower overall power consumption.
What do you think?
Just searching the web for others who have wanted to keep times short when writing to an SD card, I did find the following comment you might want to consider -- not as fact, but as motivation for you to work harder in understanding what's ahead of you.
The comment was (found here):
Reading the specifications, it should "typically" take 0.5 ms to write a block, with a worst case of 240 ms. What I find is a rather steady 100 ms. If I can't reduce this, it would burn a lot of power and require a re-design for bigger batteries.
The writer of this, above, did appear to have read the specification, as they noted the 240 ms worst case (which is, as we can now read, actually 250 ms.) So that adds some credibility to the question and to the note about what they are actually finding, in practice, as well.
It's one data point, of course. But it should provide some motivation for you to really knuckle down and understand what the SD card specification allows.
  • \$\begingroup\$ Thank you for the detailed response. You are correct, I will need to do some more 'homework' and I will let you know if more questions come up in my findings. \$\endgroup\$
    – Izzo
    Commented Oct 18, 2016 at 13:44
  • \$\begingroup\$ @Teague Sorry about bearing the bad news about all that reading. But we all have to do it when we design things. Even when we decide to use libraries. \$\endgroup\$
    – jonk
    Commented Oct 19, 2016 at 7:58
