So I had a truth table and using a Karnaugh map I simplified a function. I obtained.
\$ f = \overline{A_3}A_2\overline{A_1} + \overline{A_2}\overline{A_0} + A_3\overline{A_0} \$
Then using the distributive property of boolean algebra:
\$ f = \overline{A_3}A_2\overline{A_1} + \overline{A_0} (\overline{A_2} + A_3) \$
Ok, with this we have the minimum of logic gates to use.
Now I need to convert this to NAND. What seemed easier to me was to take the logigram (or electrical scheme) and directly change the gates to their equivalents with NAND. I obtained:
\$ f = \overline { \overline{\overline{A_3}A_2\overline{A_1}} \cdot \overline{\overline{A_0} \overline{A_2 \overline{A_3}}} }\$
Now I have two questions about this:
How should I proceed algebraically to pass to one expression to another (I know I need to apply DeMorgan laws or use the complement of the function... I would thank if someone can give like a tip or something on how to start doing it.
I'm thinking if there is any way to simplify the NAND expression... I see that I have \$ A_2 \$ twice and also \$ \overline{A_3} \$ twice... I'm thinking if there is any way to go even further in the simplification... If someone could also give a tip on how to proceed to not ruin the rule of using NAND only. Thanks very much!
