I am using PCA9685 in a project. 3 are on the same i2c bus and thus I need to change the address of individual ICs. It has 5 selectable address bits as shown in the figure below:
PCA
The address will change depending on whether A0...A5 are tied to GND or VCC.
Datasheet says that:
To conserve power, no internal pull-up resistors are incorporated on the hardware selectable address pins and they must be pulled HIGH or LOW.
Does it mean I need to use external resistors for pull up or pull down or am I allowed to directly connect the address pins to GND or VCC as per my requirement?
You can do both. What they mean is that, if you connect the pin to either GND or VCC, there will be no current wasted due to some internal pull-up/pull-down.
But whether you connect it directly or through a resistor does not really matter. I suggest you connect them directly for simplicity.
  • \$\begingroup\$ Thanks dim. To save component cost and PCB space, I am going to tie the pins directly to VCC and GND. \$\endgroup\$ Oct 18, 2016 at 13:18
  • \$\begingroup\$ That is what I'd do as well. I edited my post accordingly, by the way. \$\endgroup\$
    – dim
    Oct 18, 2016 at 13:19
    \$\begingroup\$ In a production design, your test engineer might prefer you connect through a resistor so the tester can override the pull-up/down and test the chips connectivity completely. In a hobby project, you don't need to worry about this. \$\endgroup\$
    – The Photon
    Oct 18, 2016 at 15:37
