I have interfaced PCF8591P 8-bit ADC IC to my PIC24F application board. My PIC runs at 2.8v which is sufficient for ADC input voltage provided from datasheet. I have connected LM35 and LDR sensor to the analog 0 and analog 1 pins respectively.
Code works well, but I am getting the constant output 128 for all channels, even when the sensor output level changes. Please help me for the issue.
#include <stdio.h>
#include "p24FJ128GA202.h"
#include "uart.h"
// calculate baud rate of I2C
#define Fosc 32000000
#define Fcy (Fosc/2)
#define Fsck 100000
#define I2C_BRG ((Fcy/2/Fsck)-1)
int main()
unsigned int Adc_pcf=0;
InitProcessor();
Delayms();
while(1)
Adc_pcf = I2C_read(0x90,0x00);
Delayms(1000);
uart1str("ADC0=");
uart1str(int_char(Adc_pcf));
uart1str("\r\n");
Adc_pcf = I2C_read(0x90,0x01);
Delayms(1000);
uart1str("ADC1=");
uart1str("\r\n");
void InitProcessor(void)
// Oscillator 8mhz no pll
OSCCON = 0x0011;
CLKDIV = 0x0000;
// Configure Digital pins
ANSA = 0x0003;
ANSB = 0x0000;
// Assign IO values for Ports
PORTA = 0x0000;
TRISA = 0x001B;
TRISB = 0x468f; // 7 as receive and 8 as transmitter
//PORTB = 0x0000;
// Interrupt Bits
INTCON1 = 0x0000; // Disable Interrupts
INTCON2 = 0x0000;
// Init I2C
I2C2CONL = 0x8000;
I2C2CONH = 0x0000;
I2C2STAT = 0x0000;
I2C2BRG = I2C_BRG;
//I2C2BRG = 79;
Delayms(1000);
Init_rtc();
void Init_rtc()
I2c_Write(0xde, 0x07, 0x10);
I2c_Write(0xde, 0x06, 0x00);
Delayms(20);
/* Function to Read and return a data through I2C */
unsigned char I2C_read(unsigned char DeviceAddress,unsigned int Addr)
{ unsigned char db, ReadState=0,I2CFlag;
ReadState = 0;
IFS3 &= ~0x0004; // Master I2C interrupt flag
I2CFlag = 1;
I2C2CONL |= 0x0001; // SEN = 1;
I2cTimer = 0;
while(I2CFlag){
if(I2cTimer > 30){ // Exit routine
I2CFlag = 0;
//uart1tx('r');
if(IFS3 & 0x0004)
I2cTimer = 0;
IFS3 &= ~0x0004;
if(ReadState == 0)
I2C2TRN = (DeviceAddress & 0xfe);
if(DeviceAddress == 0x90)
ReadState = 1;
else if(ReadState == 1)
I2C2TRN = Addr >> 8;
else if(ReadState == 2)
I2C2TRN = Addr & 0xff;
else if(ReadState == 3)I2C2CONL |= 0x0002;
else if(ReadState == 4)I2C2TRN = (DeviceAddress | 0x01);
else if(ReadState == 5){
I2C2CONL |= 0x0008; // RCEN = 1, Enable data receive
db = I2C2RCV;
else if(ReadState == 6){
db = I2C2RCV; // Read Data
I2C2CONL |= 0x0020; // ACKDT = 1, Set Acknowledge bit (No Acknowledge)
Delayms(5);
I2C2CONL |= 0x0010; // ACKEN = 1
else if(ReadState == 7)I2C2CONL |= 0x04; // PEN = 1, Stop enable bit forI2C
else{ReadState = 100; I2CFlag = 0;}
ReadState++;
if(db)
return db;
else
return 0;
But I am getting the o/p as:
ADC0=128
ADC1=128
ADC to PIC pin configuration:
adc0 - temperature sensor
adc1 - LDR
adc2 - left
adc3 - left
A0 - ground
A1 - ground
A2 - ground
VSS - ground & PIC ground
SDA - PIC SDA
SCL - PIC SCL
OSC - ground
EXT - left open
agnd - ground
vref - 2.8V
aout - left open
VDD - 2.8V supply from PIC power source
Update: After suggestion from SamGibson for adc read cycle i have updated the read function
unsigned char pcfwrite(unsigned char DeviceAddress,unsigned int Addr)
ReadState = 0;
I2CFlag = 1;
I2cTimer = 0;
while(I2CFlag)
I2CFlag = 0;
Error = 25;
if(IFS3 & 0x0004)
I2cTimer = 0;
IFS3 &= ~0x0004;
if(ReadState == 0)
I2C2TRN = DeviceAddress ; // Device address
I2C2TRN = Addr; // control byte
I2C2CONL |= 0x0002; // PEN = 1, Restart for I2C
db = I2C2RCV; // dummy read which will be last adc written value
db = I2C2RCV;
Delayms(5);
else if(ReadState == 5)I2C2CONL |= 0x04; // PEN = 1, Stop enable bit
else
ReadState = 100;
I2CFlag = 0;
uart1str("I2c stopped\r\n");
ReadState++;
if(db)
return db;
else
return 0;
