I am looking at a filter design in the ARRL handbook for radio communications. It is a bandpass filter designed to pass 144Mhz with a bandwidth of around 12Mhz.
The solid line represents a shield to prevent "stray coupling". \$ C_{c} \$ is a capacitor that "top couples" the two sections of the circuit. The posts labeled "C" are trimmer capacitors designed to tune the resonance of each coil. They connect the top ends of the inductors to ground.
I'm planning on implementing this for a receiver I am building.
What is "top coupling"? I'm confused, because the book says that the two sections are inductively coupled, but yet they are shielded and the diagram suggests that they are capacitively coupled.
Practical question: To shield the two circuit segments, should I use aluminum foil, or something else?
