One common misconception in electronics is that a wire not connected to anything will have a voltage of "zero volts".
Most people seem to understand that in a typical circuit with lots of stuff connected to "+5V",
there should be one thing (typically a connector accepting power from some outside power source, or a battery connector, or etc.) that actively drives that wire to +5V, and lots of loads (such as an ATmega processor or a LED driver or a 74x00 series chip or etc.) connected to +5V that consume power.
When only loads are connected to a +5V wire, KiCAD doesn't see how they are getting power, so the KiCad ERC correctly warns you that as far as it can tell nothing will get power.
(When I have a battery and a flashlight bulb, and I only connect a GND wire between them, leaving the other side disconnected, the bulb stays dark).
For some reason, people don't always pick up on the fact that GND acts exactly the same way.
There should be one thing (typically a connector accepting power from some outside power source, or a battery connector, or etc.) that actively drives the GND wire or the GND plane to 0V, and lots of loads (such as an ATmega processor or a LED driver or a 74x00 series chip or etc.) connected to GND that consume power.
When only loads are connected to GND wire, KiCAD doesn't see how they are getting power, so the KiCad ERC correctly warns you that as far as it can tell nothing will get power.
(When I have a battery and a flashlight bulb, and I only connect a +5V wire between them, leaving the other side disconnected, the bulb stays dark).
For the vast majority of integrated circuits, both +VCC and GND are power inputs. Something else needs to actively drive both of those pins to the right voltage, or the chip won't work.
This is related to the common misconception that electrical charges carry electrical energy -- the incorrect idea that batteries somehow "fill up" electrical charges with energy, the incorrect idea that "energetic charges" carry that energy through the +5V line to the chip which drains the charge of energy, and then the incorrect idea that "non-energetic charges" flow back through the GND wire to the battery to be charged up again.
In fact, electrical energy flows from the battery to the IC in one direction (from the battery to the chip) near the +5V and the GND wires at a large fraction of the speed of light.
Simultaneously, electrical charges flow in opposite directions (one from the battery to the chip, the other from the chip back to the battery) inside the +5V and the GND wires at perhaps a few millimeters per minute.
What's important for most circuits (and supported by KiCad's ERC/DRC) is the the flow of electrical energy.
"Electricity" misconceptions spready by textbooks.
