What is the difference between the two products below?
PowerBoost 1000 Charger - Rechargeable 5V Lipo USB Boost @ 1A - 1000C
USB LiIon/LiPoly charger - v1.2
I want to charge a battery that I am using with a Raspberry Pi project.
closed as off-topic by Voltage Spike, Daniel Grillo, Scott Seidman, brhans, dim Oct 28 '16 at 11:34
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Why don't you embed the pictures in your question and add details of the input and output specifications for each device rather than have a hundred EEs do this. In other words do some work yourself. \$\endgroup\$ – Andy aka Oct 24 '16 at 7:52
The PowerBoost 1000 Charger includes a boost converter that can handle up to 1000mA (1A) at 5.2V output:
Solder in the USB connector and you can plug in any iPad, iPhone or iPod for 1000mA charge rate.
While the USB LiIon/LiPoly charger is only a battery charger, that means that you can only get whatever voltage the battery is at out of it (somewhere between 3.7~4.2V).
Most RPi setups are powered by 5V in its micro-USB connetor or at the header. So if you dont have a step-up converter, the first option is a more versatile solution.
If you are already powering your RPi directly with your battery and that works well for you, the second one will be enough. (However I dont think you can charge the battery while powering the RPi at the same time).
So if you need/want to charge your battery and power your RPi at the same time, back to the first option.
With a built-in load-sharing battery charger circuit, you'll be able to keep your power-hungry project running even while recharging the battery!
  • \$\begingroup\$ Some variants of the RPi can be powered directly from a LiPo battery on their 5V input, but USB peripherals might complain. \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 24 '16 at 0:27
  • \$\begingroup\$ @IgnacioVazquez-Abrams -- nice, I didn't know that. I added some more info on the answer to account for that case. Thanks. \$\endgroup\$ – Wesley Lee Oct 24 '16 at 0:33
