I have a RC filter on which I need to increase the capacitance. I have one 47uF ceramic capacitor and 2 47uF aluminum electrolytic ones at home. Can I use these in parallel in the RC circuit? Thank you for your help!
  • \$\begingroup\$ For what kind of signal? And what arrangement of filter? \$\endgroup\$ – Majenko Oct 24 '16 at 14:12
  • \$\begingroup\$ PWM going from 0 to 5V. \$\endgroup\$ – Eliott W Oct 24 '16 at 14:13
  • \$\begingroup\$ How much current are these capacitors being asked to handle? Is this circuit part of the power stage of some kind of amplifier or power supply? \$\endgroup\$ – pgvoorhees Oct 24 '16 at 14:41
For a low-pass filter for PWM where the voltage is always the same polarity yes, you can use multiple electrolytics:
You might also consider a "Pi" RC circuit:
For lower losses it is better to replace the resistor with a suitable inductor to make an LC circuit.
