PIC18f67j11. For F_OSC which one i have to use: My crystall oscillator frequency or the real frequency oscillator including my PLL modifications?
I'm trying to match the baudRate of the UART and doesn't work. i've tried all reg configurations and baudRate formulas but none of them seems to work.
I'm using a 20MHz external crystall (connected in OSC1 and OSC2) with maximum PLL (OSCTUNE.TUN = 01111) xtal for a 4800bit/s to measure energy by the MCP35F501 meter CI.
Here is the clock code selection:
#define F_OSC 20000000
#define FOSC_PLL 20000000 * 4
#define FCY F_OSC / 4
`// seleciona clock
OSCCON = 0xF0; // INTOSC = 8MHz; SCS = 00: default primary oscillator
OSCTUNE = 0b01011111; // PLL = ON; TUN = 011111: Maximum frequency`
And my UART config:
void configureUart(unsigned char uart, unsigned long baudRate) {
RCSTA2bits.SPEN = 1;
RCSTA2bits.CREN = 1; // Habilita recepção
TRISGbits.TRISG1 = 0;
TRISGbits.TRISG2 = 1;
TXSTA2bits.BRGH = 0; //Low Speed Mode (baud = 8bits)
TXSTA2bits.SYNC = 0; // 0 = Asynchronous Mode
TXSTA2bits.TX9 = 0; //Transmissão feita em 8 bits
RCSTA2bits.RX9 = 0; //Recepção feita em 8 bit
BAUDCON2bits.BRG16 = 1; //16bit Baud Rate Generator
TXSTA2bits.TXEN = 1; // Habilita transmissão
UART2_RX_INT_EN = 1; //
UART2_RX_PRIORITY = 0; // Baixa prioridade de interrupção
baudRate = 1050;//(unsigned long)(FOSC_PLL / (baud_rate * 16)) - 1; TRYING TO MATCH MANUALY TO VALIDATE THE PROTOCOL :#
// Calcula o novo valor para o registro de configuração do baud-rate
SPBRGH2 = baudRate >> 8; // Atualiza BRG da UART1
SPBRG2 = baudRate; // ...
baudRate = (FOSC_PLL / (baud_rate * 16)) - 1; //FOSC_PLL = 80MHz.
What can happen if i mantain the Pll over the maximum? \$\endgroup\$ – Henrique Oct 26 '16 at 15:42
