Need help to indentify this IC, i have googled for "CD10347", "B20", "N02". And can't get a match. Need the datasheep and a replacement part.
Thank youenter image description here
  • \$\begingroup\$ Ah it seens i was searching for B20N02 instead of B20N03, my mistake... Thank you for notice. Still can't find a CD10347, would a CGD0460 replace that? \$\endgroup\$ – Tiago Conceição Oct 26 '16 at 17:13
Try searching for B20N03 and not 02
It's made by the Excelliance MOS corporation and is a MOSFET, 30V, 12A.
  • \$\begingroup\$ Ah it seens i was searching for B20N02 instead of B20N03, my mistake... Thank you for notice. Still can't find a CD10347, would a CGD0460 replace that? \$\endgroup\$ – Tiago Conceição Oct 26 '16 at 17:14
    \$\begingroup\$ That might be some batch code or date code. Given that it is only a MOSFET, finding a replacement from Fairchild or IR or TI shouldn't really be a problem. \$\endgroup\$ – Andy aka Oct 26 '16 at 17:16
    \$\begingroup\$ p.3 of the datasheet indicates that this is just a date code. \$\endgroup\$ – brhans Oct 26 '16 at 17:17
  • \$\begingroup\$ Yes part look equal to me, still i will ask seller. Better be safe. \$\endgroup\$ – Tiago Conceição Oct 26 '16 at 17:17
  • \$\begingroup\$ @brhans Thank you, will order some, that solve my problem. Thank you for helping out \$\endgroup\$ – Tiago Conceição Oct 26 '16 at 17:18
