Schmitt Trigger CMOS! How does this circuit work? why do you get different threshold voltages for increasing and decreasing Vin?
  • \$\begingroup\$ What do you know about these FETs? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Oct 27 '16 at 3:03
  • \$\begingroup\$ Only that P:N ratio is 2:1 \$\endgroup\$ – user127565 Oct 27 '16 at 3:14
This circuit is typically used to change the trip point of a standard inverter. If you look closely you'll find that the size of the feedback MOSFETs play a major role in deciding the Vin at which the output will switch from low to high or vice-versa.
Vih, is the input voltage at which the output switches from high to low. The source voltage of N2 is reponsible for that. Now the N2 source voltage depends on the output voltage, size of the feedback nmos. The more the width of feedback nmos N3, lower will be the Vih. Same holds true for the low to high condition in the Pmos side (which affects the Vil).
  • These FETS would use Vgs of 1.5V so that P3 and N3 switch their respective sources to between 3.5~5V and 0~3.5
  • the N12P12 gates are wired as "AND" logic with N3P3 forming 2 inversions and positive feedback to shift the levels for Vgs on N2P2
  • \$\begingroup\$ If Vdd exceeds twice the gate-source threshold voltage, it would seem that if the output is high and the input is at Vdd/2, there would be a Vdd->Vss path through N3 and N1. Perhaps one could size components so as to limit the current, but that seems rather dodgy to me. \$\endgroup\$ – supercat Aug 22 '17 at 21:14
  • \$\begingroup\$ I believe all logic is designed this way with controlled RdsOn during crossover to limit transition current. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 22 '17 at 21:45
