What I am doing is I have cut off some bulbs off a string of incandescent Christmas lights. However, now I need a resistor for it so it doesn't blow the bulbs out.
Without a resistor, within a few minutes it blew all the bulbs on that half of the string, and now I understand the reason is because the bulbs I removed caused a greater load to be placed on the remaining bulbs.
I am almost done, and I even soldered the resistor onto the string properly.
However, because of the following two factors, I believe it is the wrong resistor, perhaps because I need a resistor to handle much higher wattage, per my speculations. * resistor got too hot immediately * bulbs were too bright like without any resistor, indicating the resistor was not taking the load as expected.
Now, keep in mind that not only am I just trying to have good Christmas lights but also I am doing this as a learning experience. Obviously I could just take it down and use an unmodified string, but I want to learn so that is why I want to use the resistor.
Here is my diagram:
Project details:
I removed 27 bulbs from a 100 bulb set, from one side.
You can see in my diagram how these lights are wired.
The Math (my math is wrong, see below*):
So I did all the math, and I know all the variables I need for the project.
1.2v x 27 bulbs = 32.4 v
.408w x 27 bulbs = 11.016 w
amps = 0.34 a
ohms (Ω) = 95.29412 Ω*
>>>> *NOTE: Math is wrong, see update below. Keeping this here for reference.*
(NOTE: I calculated ohms using online calculators. I used this one: http://www.ohmslawcalculator.com/ohms-law-calculator. I also double-checked using other online calculators, with the same result.)
Ok, so according to the radioshack guy, all I needed was a 100 ohm, 1/8 w resistor, he said there is no need for a bigger wattage.
So I went and soldered on a 100 ohm, 1/8 watt resistor, but I noticed that first the bulbs were too bright like before, so it seemed like the resistor wasn't taking the load as expected. Second, the resistor got immediately so hot it burned a hole through the electrical tape within seconds.
So I unplugged immediately and now I am researching the correct solution.
I am wondering is if he had no idea what he was talking about and if in reality, I needed a 100 ohm, 11+ watt resistor?
Also from searching the web I read that a standard is to get twice the wattage of your needs for the resistor.
I have also already done all the connecting, testing and soldering. I just need to know which is the correct resistor to use for my project. Once I have that I can just attach it in place of the wrong resistor and then everything should work!
Please let me know if I need the 100 ohm, 20 watt resistor, or if not which is the correct resistor.
Thank you in advance!
UPDATE:
Ok, so commentors are saying that due to the KVL law of physics, actually it is not 120v split evenly into both strings.
Instead, it is 120 v into EACH string. This changes things.
Also another answerer said that amps is split among the parallel circuits. So looks like I had it backwards originally.
New formula:
120v / 50 bulbs = 2.4v per bulb
2.4v x 27 bulbs = 64.8v for the 27 bulbs.
2.4v x 27 bulbs = 64.8v v
0.34a/2 parallel circuits = 0.17 a
watts = 11.016 w
ohms (Ω) = 381.17647 Ω
So in this case, does this mean that I actually need:
~381 ohm, ~20 watt resistor?
(~ means here "around" since an exactly 381 ohm resistor doesn't exist.)
(20W because 11W is needed and due to research good rule of thumb is double wattage needed)
