I'm trying to create a small Arduino project where I have to attach it on an appliance that has a tactile switch. I want this to be detachable/modular solution that way I can re-use it on other appliances with little or no modification needed. But i'm not sure what component do I use that will do the pressing to those switches.
Is there a pre-made component that can do a push function or do I use servos to mechanically do that? Is there a similar projects on the internet that is similar to my problem?
  • \$\begingroup\$ When you say "appliance" do you mean a mains-supplied appliance? \$\endgroup\$ – jonk Oct 27 '16 at 20:47
  • \$\begingroup\$ sorry, I meant electrical appliances (e.g. microwave). I might have been too generic. Here's an example of those buttons i63.tinypic.com/2wqbneg.jpg \$\endgroup\$ – Pennf0lio Oct 27 '16 at 21:02
    \$\begingroup\$ I think what you are looking for is a solenoid. It's a linear actuator which uses the electromagnetic effect to pull on a pin. This pin could be used to push a simple button. adafruit.com/product/412 << something like this should foot the bill \$\endgroup\$ – ambitiose_sed_ineptum Oct 27 '16 at 21:03
  • \$\begingroup\$ Yes, I think this will work! Do you also happen to know something more compact than this? I just find it too tall? It's just for aesthetics :) If not, I think this will do. Again, thank you! :) \$\endgroup\$ – Pennf0lio Oct 27 '16 at 22:34
    \$\begingroup\$ It would not be too hard to rig up a L-shape hinged lever that translate the horizontal motion (of a horizontal mounted solenoid) to vertical motion. It would also give you a place to trade off the travel distance vs force. \$\endgroup\$ – rioraxe Oct 28 '16 at 6:23
