I have a set of christmas lights I have shortened. I don't understand what is happening here.
Both wires work to light the second half, but when I connect it all together (1), the light on the first half does not work??
In (2) and (3) I showed that power is still passing through both wires, except that it does not light the first half. So the problem is not a short in the wires themselves.
In (4) I show that the bulb lights up when I put them in series. So I also know the problem is not the bulb.
What is going on here? I don't understand what I am missing.
Here is a picture showing illustrations:
UPDATE:
Ok, so by looking at a new uncut set, I have learned that the original was NOT in fact wired like above. Thanks to a commentor who pointed out that it is short-circuited, I went to a new set and learned that it was not wired as it originally looked. I also cracked open one of those lights with three wires to see what it looked like inside.
Here is a modified diagram of the actual wiring of the original. I popped off the bulb so you can see how it is attached:
